i agree with bro vr2... maybe just mod it to look good.. 15 inch rim.. avy bodypart... new paint.. its gonna look sick bro..
Viva is a powerful car, auto is better, as auto you can control gear shift with your throttle, only is that if you use revving hard on auto, you must add atf cooler, to protect the auto gearbox, next you can upgrade front brake with a myvi front caliper and rotor brake set, then you can choose bucket seat (i prefer fully bucket, cheaper and serve the purpose). and most important i will get a set of lowered spring to match the sporty feel. yours is viva elite right? then appearance wise no need to do much, as it is very nice already, just need lowered.
---------- Post added at 11:50 AM ---------- 6 hour anti-bump limit - Previous post was at 11:48 AM ----------
steering no need to change, follow japan style, they only change parts that need upgrading and retain those parts that can be used.
Glad you understand, to me just that Viva is not a car to be mod fast.....:rolleyes:
. follow road speed limit to b safe
That should be your first mod. Good luck, and remember other cars on the road are innocent. They are people's son, daughter, wife, husband, father, mother, brother, sister.
oi.. y put my name here hahaha!! small potato only my car.. saja tak tau malu go sepang lol
anyways, these were my mods on my slow auto trans viva elite.
-Genuine Apexi Power Intake Open Pod K-Car Spec + Custom Alu Ram Pipe (recommended to use drop in)
-Works Lightened Crank Pulley
-Works Engineering Magnetic Oil Sump Nut
-Dsports 1.3bar Radiator Cap
-Forged Racing Radiator Fan
-Hayden ATF cooler
-Full SS Exhaust System (3-1 Manifold) piping try with 1.5" or 1.6" max for NA, anything more is too much
-UltraRacing 2pt Front Upper Struts
-UltraRacing 3pt Rear Bar
-UltraRacing 3pt Fender Bar
-UltraRacing 2pt Anti Roll Bar 18mm
-UltraRacing 2pt Rear Lower Arm Bar
-Dsports Front Sway Bar
-Stiffrings Rigid Collar
-BC Racing V1 Series Street and Circuit 30pt HLSH Coilovers (from a MYVI 1.3, fits into viva)
-Large single pot caliper + R32 280mm Crossed-Drilled Rotor + (Track :480*C Pads) (Street :420*c Pads) [single pot is good enough, twin pot and beyond is overkill for such a small car]
-Pro-RS Steel Braided Brake Hose [shitty hose, broke and almost killed me. recommended to use SuperCircuit hose]
-Kumho KU31 Ectsa SPT Street Rubbers [165/50/15, the only good tyres for this size back then, works like a charm in Sepang]
-TPI Lugs Nuts
-Genuine Desmond Evo Regamaster 15x6.5jj [If possible, recommend you to use 14" with 165/55/14 because Achilles recently launch new semi slick - ATR K Sport for this size]
-NRG Gauge
-Lubed by Motul 300V, Motul ATF, Motul Coolant
Was considering for a k3vet swap till i decided to change car LOL!
anyways if i still have the car, the following NA mods will be done to it
-Velocity Intake Manifold
-14" rims with Achilles ATR K Sports
-Port & Polish [NastyPortFlow]
-probably emanage / unichip it to squeeze that extra 4-5 whp and torque from the mods :)
any further would be BOT or k3vet swap, but im more of a handling kinda person than power hunger, hence u see mostly handling mods done. With the above setup, the car handles like a go kart, but kinda stiff for daily use. anyways, viva is a light car and a very fragile car. not suited for high speed use.. drive safe and have fun modding! :)
melvin,
your car is the only viva that enter sepang trackday....must be fully modded..but i liked your viva....
sold it off edi ah?
-Hayden ATF cooler
-TPI Lugs Nuts
-NRG Gauge
sure why not.. all items stated above just plug and play items
From you, now I get to know what to mod in Viva if I own one of it in the future.hmm.. well fiesta also going on the similar pathway mods. but all i can say is viva handles like a go kart with all the mods haha. can tackle almost all corners i encounter on the road with minimal to no braking hehe
couple with good fc, small and happy car, easy to park everywhere... not a bad car after all. just that gotta drive slow.. ive tried up till 160kmph before on north south highway, pretty scary driving a k car up to that kinda speed. safety definitely an issue, but then again. good town driving car
fiesta of course better power delivery and good handling right out from the box with no mods. all in all its a different category all together haha. but then again, the experience gained is priceless. really learn alot about handling, how each and every part affects handling characteristics and also it is cheaper to mod a viva than a fiesta. so now im using those experience to slowly mod my fiesta step by step :p
still a loooong way to learn from all the sifus lurking here in zth. time to explore more on the power department :)
Dear member,we would like to invite u to share bundle joy of our baby Lucas 's full month celebration on 9th Oct at 8pm sharp in my house,RSVP by 2th Oct and thank you
