Clean headlights with toothpaste
Try CSM hardware in Shah Alam. I remember seeing the 3000 grit if not mistaken.
Anyway, yup some use up to 2000 only as that is pretty fine already, then follow up with polish...
---------- Post added at 07:54 AM ---------- 6 hour anti-bump limit - Previous post was at 07:53 AM ----------
If yellow then no need sand. I mention peeling. Some headlamp can see top yellow layer peeling away from the main plastic, then to remove need some wet sanding...
Mine if look closer, can see some fine lines of cracks inside...is not exactly crack but there are lines that form the likes of crack lines...
If the lines are inside then cannot do anything woh!
---------- Post added at 02:46 PM ---------- 6 hour anti-bump limit - Previous post was at 02:43 PM ----------
It's like micro cracks right? Is that's peeling?
Peeling you can see a layer coming off the headlamps...
i did use the XXX toothpaste on MYVI headlamps...it appears the headlamps look much much better compared to previous condition...but not glossy...ok lahh...
LesleyAprotto san...I cant reveal the brand name of the toothpaste lorrr...hahaha...the toothpaste that I bought indicates 'xtra whitening'...:rock:
If it worked well on your headlamps then you can provide the brand. Then when that toothpaste sells well, you can go and collect commission from them....:rofl:
Extra whitening and gum or cavity protection all the way. Cleaning and protection ma :rofl:
Btw, I know they works to remove the dull outlook on headlamps but I still prefer polishing. Make sure no white stain as it'll build up in the long run.
