did the rev test and it goes past 4k rpm.
when the ecu uses the external chip ( j1 shorted) the main relay tics only once, and the fuel pump never stops running,,
its like ecu is not stopping the second relay inside the main relay however,
when i remove the chip and J1, the main relay tics twice then CEL goes OFF, after 5-6 sec. CEL ON, not throwing codes,
I tried to pull one sensor plug air temp sensor, and key ON, relay works, pumps stops, CEL ON, did the diagnotic plug, threw code 10. so ecu is working
check sta413a - good
injectors works
car starts
badly need help.
thank you in advance
