evo 3 problem.
Sep 10, 2012
2
Grenada
my evo 3 was workin so sweet until the timing belt burst. damage some valves. i replace the bent valves and bolt back up the head.all the mating marks are dead on but the car not running how it use to. i double check the timing over and over and it dead on .any helps for you guys?
ed78
353
29
Were there any other damages to the head? was the head skimmed well after fitting? it may cause leaks and lost of pressure........... piston damaged?
jinkl
4,623
376
3,183
thts the reason i wont replace valves or etc , bent ? throw the head away, cause there might be small small stuff tht we dont notice owith a naked eye
perry gazoo
2
Grenada
No the block is fine. i did a compression test and its ok.
---------- Post added at 07:57 PM ---------- 6 hour anti-bump limit - Previous post was at 07:56 PM ----------
also i notice the belt need a little more tension. that could be the cause?
huakenny
LB Performance
9,126
240
Kota Kinabalu
if compression test ok, check the balance shaft n timing marking....wat head gasket using?
ok guys...now i reli reli pening...im having a dilemma & nightmares on which ADJUSTABLE COILOVERS to get..these are my choices...(prices stated r for wira gsr)
1. NEW gab adjustable, hi/lo - RM1.9k..these are claimed to be local assembled with the parts & technology fr japan...took a test drive in a perdana v6 wif these shocks n it performed nicely...quite to my liking..but dunno about its reliability
2. NEW hwl mt1, hi/lo - RM1.6k..heard from MANY shops that the HWLs are very prone to...
