- Joined
- May 7, 2006
- Messages
- 1,030
- Points
- 1,648
hahahaha. satria r3 with jun 272 cam. this is monster!
Just collected my b16a intake manifold which was welded to a 4g93 IM flange (spare one i have lying about). The weld quality is good and the inside parts where the weld connection is are all smooth, probably needs a bit of polish to satisfy the perfectionist. To top it of, it was sand blasted so it looks heaps better than when i dropped it off
If anyone wished to do this mod i.e. don't know of any foreman capable of doing this, i can intro you
klipsch..
where in klang are u? i'm staying around Telok Panglima Garang/Bdr Parklands area. In the process of DIY fitting Edelbrock victor x. Mine is d ori one so wont be cutting n weld the flange,plus already sourced Golden Eagle f.rail+Blackworks 72 tb.
Where in Klang can i machine an adapter flange? would be better if i could blend the adapter flange to intake ports to promote smoother flow/higher velocity.
If not possible than my solution would be port matching d Victor x ports with my 4g93t head ports.
Anybody that can assist?
tqvm
I cut the skunk2 myself using grinder. It fits perfectly well. However, I'll soon be taking it out to cut n weld 4G9X flange.
Yes, modding the B flange to fit 4G9X will work and look nice with the Honda fuel rails. However, The injector sprays towards the outer valve port in every port esspecially for port 1 & 4. It's 3mm away from the center of the port. If we're using FIC and Denso injectors with Twin tip which the 2 tips is just separated 1mm away.. All the fuel will enter via 1 valve only. Because there's a devider between 2 inlet valve in each port.
Then again. I see no problem with modding B flange. I've been using it for a year +. But i would like to balance the spray between valves.
Just my 2 cents.
Yaya... I'm using FIC too.... But...
This is what I meant.
Sorry for modding your picture.
On the port side.
.Hi frenz..just to share my Diy :stupid:b series intake can fit to 91,92,93 single or doch head.Mivec also can la.i'v make alot to my frenz..juz want to share Diy...all circle hole must reweld back coz not realy match,specialy hole 1&4.than match port with gasket head la...then recut and some must topup weld to make the flange same like gasket use than port for look like ori.drill stud hole,skiming flange face.the last is to make munt for acesory like coil,sensor,cable,T.B(match port) etc. i prefer to use feul rail B series back..want to look cun use from EG.than polish until shine...but if u use 93 injector.the rubber injector oil ring at B series must port coz to fit...to make like this more coz la..but good match port and look like ori fit....but if my frenz want look more ori..then i make like this red wira terus dia puas hati:hmmmm:
