Need all Cefiro member to give opinion & info on A32...
Sil80-13
Hi guys,
I am thinking of getting a A32 year 97 3L as it's quite cheap in the market due to the roadtax. I wanted to convert the 3L into 2.5L engine & other specs like below. Need you guys to share with me if you know the price as I need to calculate before I proceed to buy a A32. Thanks in advanced.
1. A32 2.5L V6 half-cut including everything classified as whole half-cut - RM????
2. Original Front & Rear Brougham conversion - RM????
3. Rear windscreen with wiper set - RM???
4. Full original leather wrap up for front & rear seat & door panel - RM????
5. 1 set of Koni absorber with Eibach spring - RM???? Is this the perfect match for A32?
6. Change the whole underneat car bushes. - RM????
As I can think of the major thing, is above 6 items. As for others like rims, paint & others, I can figure/calculate it out. Hopefully all Cefiro senior & experience guys can guide me on the $$$$$ that I need to standby for the above 6 items.
Hope to hear from you guys ASAP...:biggrin:
01) 1/2 cut Range from 3.5k to 5k
02) Not sure, maybe around 3k for taiwan parts. The original bumber is around 900 for front, the headlight is RM 550 each, and the spotlight is RM 300 each (you need 4). you do the math.
03) If you need, will have to special order maybe 1k (not sure), wiring how?
04) Leather usually around 3k to 5k depend on quality and material
05) Koni Yellow last i ask around 2.4k, Eibach not sure, maybe rm 800 - 1k?
06) Bushing is not expensive around RM 1k enough.
how about Engine mount? Oil Seal, Water hoses? Installation/labor , JPJ registration?
I'll say prepare 25k for all the above.
Wow...Which mean it's better to get those already converted? Those fully converted only selling RM30k plus. :confused:
Even converter, you need to spend few thousand for oil seal, suspension and parts. That maybe another 4 to 5k.
have seen some around RM19K, converted, but not is so good condition, so be prepared to spend a few K, up to 20K to repair/change/beautify/modify to your needs... :)
Brougham parts v expensive as you cannot get it from chop shop.
once you change the brogham front and rear bumper, you need to get the chrome lining too. original one is quite costly.
