any update..?
i`m headache to think about that coz this happen to me a week ago b4 that is ok..
bro wat clutch are u using ?
hello to all frenz..
i had problem like that...my problem is when i`m revving around 3.8k rpm above my dashbord n clutch padel got vibration..this happen when cruising n every gear changed on that rpm..
can any 1 help me to rectify the problem?i`m headache to think about that coz this happen to me a week ago b4 that is ok..
Hi guys, just bring up the old topic.
Since I experience the same situation, is it a problem?
sub8evo,
Kindly share, did you solve the problem or what are the reason causing it?
The ride are all stock condition
Bro,
Did you experience on all gears, or like my case when shifting 1st and 2nd gears only?
This is likely an indication that your clutch is worn, and its time to change.
My car is in the process of changing to a new clutch now, will know the result next week.
Stay tuned...
... thinking to use the original stock pad...It may (or may not) reoccur once new plate in i'm afraid due to the fact that e7-9 oem clutch is considered heavy duty hence juddery on
initial, behaving almost similar to a racing plate but no noticeable slips AFAIK but who knows...
bro...im having the same problem too....
1st gear car jerking
when engaging into 3rd gear, there is a sound 'krak', like gear x masuk properly....
sub8evo,
Kindly share what clutch are you using?
How the feeling during engagement?
H22-C
Still experience judder or vibration?
Thinking to change my stock worn clutch either ACT HDSS or Ogura Twin Plate.
Looking forward a stock feeling during engagement... for daily ride.
for my car E7to E9
:confused...
