- Joined
- Jun 4, 2006
- Messages
- 2,798
- Points
- 1,683
(^_^)...he...he... thanks for the advised ky_fei.
If ur oil temperature does not exceed 110C, u're still in thensave zone.
hello.
is gt2510 good for 1.6?
its from hks. here are the specs copied from hksusa.com
HKS GT2510 - 300 PS Output
COMPRESSOR:
-Wheel- 63 Trim - 47.7 Inducer / 60.1 Major
-Housing- 60 Inlet / 50 Outlet - 0.60 A/R
TURBINE:
-Wheel- 62 Trim - 53.0 Major / 41.7 Exducer
-Housing- GT25 inlet / Internal GT25 oulet - 0.64 A/R
Planning to get one (order from japan is less than 2k for a used unit) and put in my suzuki m16a. I want to play low boost 0.5-0.6bar due to my 11.1:1 compression ratio. may i know how much does a brand new gt2560R cost? hks has gt2540 too.. what engine are you running now? btw, thanks for the reply. please advice.
Thank you very much. I think I found the right turbocharger then. Thank you!
no la... im getting used units from japanese websites... from what half cut did you get the gt2560r? silvia? is using halfcut turbos safe?
Hello all,
Just wondering, whats the current market price for BOT for those that are not plug and play..
I was quoted for RM6k to RM7k for the items listed below:-
- Custom intake manifold,
- Garrett T3 (RECOND)
- Stainless steel pipings, with all silicon connector hose
- Custome Intercooler
To me its freaking expensive... I've got to get my own injectors, map sensor n metal head gasket. Does the price for stainless steel hiked up recently?
Hello all,
Hi guys I have the motor 4g92 (mmc_carisma) want to put turbynu and increased to 1.8;)
what say? advise what is needed and how best to proceed)
but then increased to 1.8 may be due to stroke or am I mistaken?change to 4G93 block. Save the hassle... If 1.8 is your aim, then no point stroking the 4G92 block. Bore up the entire cylinder wall also can't achieve 1.8L...
The stroke is too short to increase much capacity per mm of bore.
Turbocharging is not so hard on a 92. But what kind of power are you aiming at..? And what kind of reliability are you hoping for...?
well, if not to set aside 1.8 and 1.6 turbo do you like better to do? I want to do it with minimal cost and remove the 200hp + is real? another idea was to put a stock piston with a VR-4, they seem the same size as my 4g92?)
vsetaki or better to make 1.8?
but the car I'm doing every day on this I want to keep it quite economical!
