Guess what? still punctured!!!
At least I know that the problem was the rubber itself & not the rim. Like I said previously, the rubber once patched before because of a small nail.
Can we repatched the area? the tyre shop guy says that once patched it will never puncture at all.
So could it be the sidewall? because once we press the sidewall & checked it with soap water, we can see some bubbles coming out.
Is there any warranty or something?![]()
If not repaired correctly, can still leak, but since you mentioned small nail, should be okay.
Normally if larger hole, sometimes got to patch nicely, or use the umbrella shaped one to patch from inside.
Yes, it can be re patched, by taking out the old plug, then got to file the hole again and insert new plug.
Leak from sidewall? I cannot tell without seeing it myself.
If you mean warranty for the tyres, it depends. If really can find it leaking from the sidewall and no visual of any damage or curbing the tyres, you can go and ask BS about it. Could be manufacturing fault....
