Ya lor, secondhand cheap2 but still good one ca get ah? Ahaha! How I wish. Ya bro looking around which one to choose. My mechanic friend still say just for the project U 350c.You will need track day pads dy.......
Project U should be fine. Otherwise the best bang for buck i can think of is Bendix Metal King Titanium. love these pads.Ya lor, secondhand cheap2 but still good one ca get ah? Ahaha! How I wish. Ya bro looking around which one to choose. My mechanic friend still say just for the project U 350c.
350c for daily drive, track day need higher loh......Ya lor, secondhand cheap2 but still good one ca get ah? Ahaha! How I wish. Ya bro looking around which one to choose. My mechanic friend still say just for the project U 350c.
Got them at RM400 without the stabilizer bar. Found the stabilizer bar laying around my friends workshop. Lucky me.bro jambunk86. how much u bought the evo3 lower arm? need to get the lower arm together with the arb right? planning to change my wira lower arm.
Ya the Project U is the candidate.Project U should be fine. Otherwise the best bang for buck i can think of is Bendix Metal King Titanium. love these pads.
What wheels and tires btw?
instead of using an oil filter relocator, u can opt for a sandwhich plate with oil cooler outlets insteadI never thought installing an oil cooler is such a hastle. Everything is in the way. The compressor and condenser really blocking the way. If I want to keep them, each and everytime needed to change the oil filter I will need to take off the bumper(oil filter relocator only have space below the left hand side of the headlamp).
Have to say goodbye to my AC. :(
Ya bro, in the end decided not to use the relocator. But need to say bye2 to my A/C. Previously the car is with A/C. Very good still. I thot still can on A/C while waiting if need to wait before enter track.instead of using an oil filter relocator, u can opt for a sandwhich plate with oil cooler outlets instead
so ur oil filter will still be at the original position.
Boss, the ARB has been there since I bought it. 2 reason why cannot tell you what is the difference;Boss... how is your satria behaving after installing the rear ARB? I had this dilemma of not installing it...
I have not installed them ARB since having the car many-many years ago... I did drove a friend's Satria GTi on our local B-roads and trekked out a Satria 1.8 DOHC with a UK spec 1.6 body on trackday sepang but still I did not find much difference.. I think is due to the individual car setup preferences.... all I can see cars with ARB will "tripod" when driven hard into turns...Boss, the ARB has been there since I bought it. 2 reason why cannot tell you what is the difference;
1. Its been there(never feel without)
2. As for now only drive it on the street havent tracked it yet. But if tracked also not sure I can tell the difference or not. Worry if my feel is deff.
But as for my friend's experiance, initially he have his ARB on; he feels like too much grip and wanted a bit of sliding(from what I understand from the brief conversation). After taking his ARB off, the rear slides a bit to his preferance(or feel better in comparative with his ARB on).
Does that make sense? I also not sure if we do something(stiffer ARB/softer damping - example) how the car handling characteristic will change.
Ya bro, different suspension set up also maybe why cant tell the difference. Maybe need to test with and without the ARB on the same car and same suspension set up. The Satria you guys tracked, hows the suspension set up bro? Spring rate used? Body roll ok?I have not installed them ARB since having the car many-many years ago... I did drove a friend's Satria GTi on our local B-roads and trekked out a Satria 1.8 DOHC with a UK spec 1.6 body on trackday sepang but still I did not find much difference.. I think is due to the individual car setup preferences.... all I can see cars with ARB will "tripod" when driven hard into turns...
I think so... Plus all of us have a different setup OK.. I will list below:Ya bro, different suspension set up also maybe why cant tell the difference. Maybe need to test with and without the ARB on the same car and same suspension set up. The Satria you guys tracked, hows the suspension set up bro? Spring rate used? Body roll ok?
