Owning a track day car. Finally!
jambunk86
570
20
Kajang
You will need track day pads dy.......:driver:
Ya lor, secondhand cheap2 but still good one ca get ah? Ahaha! How I wish. Ya bro looking around which one to choose. My mechanic friend still say just for the project U 350c.
sanekit
Dec 9, 2015
1,616
157
bro jambunk86. how much u bought the evo3 lower arm? need to get the lower arm together with the arb right? planning to change my wira lower arm.
mADmAN
1,840
547
Project U should be fine. Otherwise the best bang for buck i can think of is Bendix Metal King Titanium. love these pads.
What wheels and tires btw?
350c for daily drive, track day need higher loh......:driver:
jambunk86
570
20
Kajang
Got them at RM400 without the stabilizer bar. Found the stabilizer bar laying around my friends workshop. Lucky me.
I think now got someone selling at mudah.my
jambunk86
570
20
Kajang
Ya the Project U is the candidate.
Wheels just normal taiwan wheel bro. 15x7. Tyre achillies 123s.
jambunk86
570
20
Kajang
I never thought installing an oil cooler is such a hastle. Everything is in the way. The compressor and condenser really blocking the way. If I want to keep them, each and everytime needed to change the oil filter I will need to take off the bumper(oil filter relocator only have space below the left hand side of the headlamp).
Have to say goodbye to my AC. :(
mADmAN
1,840
547
instead of using an oil filter relocator, u can opt for a sandwhich plate with oil cooler outlets instead
so ur oil filter will still be at the original position.
jambunk86
570
20
Kajang
Ya bro, in the end decided not to use the relocator. But need to say bye2 to my A/C. Previously the car is with A/C. Very good still. I thot still can on A/C while waiting if need to wait before enter track. :biggrin:
jambunk86
570
20
Kajang
Boss... how is your satria behaving after installing the rear ARB? I had this dilemma of not installing it... :dancing2:
Boss, the ARB has been there since I bought it. 2 reason why cannot tell you what is the difference;
1. Its been there(never feel without)
2. As for now only drive it on the street havent tracked it yet. But if tracked also not sure I can tell the difference or not. Worry if my feel is deff.
But as for my friend's experiance, initially he have his ARB on; he feels like too much grip and wanted a bit of sliding(from what I understand from the brief conversation). After taking his ARB off, the rear slides a bit to his preferance(or feel better in comparative with his ARB on).
Does that make sense? I also not sure if we do something(stiffer ARB/softer damping - example) how the car handling characteristic will change.:listen:
mirage-rs
62
10
1,508
Kajang
touger.wordpress.com
I have not installed them ARB since having the car many-many years ago... I did drove a friend's Satria GTi on our local B-roads and trekked out a Satria 1.8 DOHC with a UK spec 1.6 body on trackday sepang but still I did not find much difference.. I think is due to the individual car setup preferences.... all I can see cars with ARB will "tripod" when driven hard into turns... :fight:
jambunk86
570
20
Kajang
Ya bro, different suspension set up also maybe why cant tell the difference. Maybe need to test with and without the ARB on the same car and same suspension set up. The Satria you guys tracked, hows the suspension set up bro? Spring rate used? Body roll ok?
mirage-rs
62
10
1,508
Kajang
I think so... Plus all of us have a different setup:biggrin: OK.. I will list below:
The tracked Satria 1.8 DOHC UK spec body:
HWL hi lo coilovers,
Spring rate: 8k front, 6k rear
Height: 1 finger I guess.
Camber/toe: N/A
Tyres: Front/rear Federal 595 RS-R 205/50/R15
Chassis Reinforcement: Ultra racing 4 point bar front, 3 point bar rear.
Verdict: No massive bodyroll detected. The tyres probably covered most of the flaws.
The satria GTi we hantam on touge:
Suspension: D2 hi lo soft hard,
Spring rate: Front 8k, rear 6k
Height:1 finger also
Chassis reinforcement, Ultra racing 4 point front bar, 3 point rear bar, upper bar.
Tyres: Toyo proxes T1R 195/55/R15 front and rear
Tyre pressure: 28psi front, 30psi rear
Verdict: It was tested on wheelspin bukit putus trackday many2 years ago. No visible massive bodyroll. perfect balance of power and control (its a GTi forgodsake :biggrin: )
A decent coilovers will do... building a perfect trekker is no overnight development :driver:
KenDiriwan
1,283
225
kendiriwan.multiply.com
Not to bash of Ultra Racing ARB, but the material made are darn important. It was known among few Toyota corolla communities although the bar diameter is much thicker than other brands the response given are thus so far negative feedback. Other bars are fine but choose your ARB wisely, it might not be an improvement afterall.
Even so if your platform able to source others than UR.
hai, i currently own a ford fiesta and want convert my rear drum brake to disc.
can anyone tell me the cost for toyota AE or mazda 323 rear disc brake and custom made bracket . really wish my fiesta can having rear disc brake.
