Maintenance: Battery
Ace
715
Penang
yeap..agreed with yu. reliable relay usually cost a lot more. But the looks of your red relay is the type like our MFI relay which have even higher tolerences where it need to supply huge amount of juice to the starter and elec ignition coil. You can try touch the wire after driving a while and you will feel very hot on the wire.
Yu911
425
www.cardomain.com
never touch the wire before, but I know is very hot, the ori wire at the fuse box is harden liau.
The red relay input & output conector point is very very big, normal clip can't clip to it, must use a big clip to do so.
Ace
715
Penang
yu,
looks like all your stuff is big. engine big, rim big, tyre big, horse power big even relay also big. heheheh what else ah?
Daniel Lee
2,950
4
Yu, why you didn't get a whole set?
Mazda RX7 brake discs can fit nicely ah?
Do you know how much for those RX7 discs?
I'm still searching for a new front and rear disc brakes for my Coupe.
Always dream of Skyline GTR's brake discs with 6 pots Endless calipers. hahaha....
Yu911
425
www.cardomain.com
get a rb26 will do, right BS?
never fit lah, lots of modi, that is why I ask BS not to change but change to better pad, but if for good looking than ok lah.....
RX7 4 pot I get it from my friend for about RM 350 I think, but the camry from chop shop about RM 600 if I'm not wrong
BlackSamurai
9,000 RPM
9,656
24
near 7-11
www.hcc.ne1.net
Daniel, earlier i was looking at this.
http://zerotohundred.com/newforums/showthread.php?t=103384
1. I wanted to upgrade because I think Coupe need a better brake, especially when you travel high speed, the stock brake is just not enough to support 200KMH.
2. for Look lah, my 17" very empty inside :biggrin:
But Yu told me better not to...
Ace
715
Penang
BS,
That is why I choose my the design for my rim which can;t see inside at all.
RWD can cause the car to have more oversteer and AWD make the car to have more understeer when coming to corners
Even Nissan GTR R33 & R34 in Japan GT is modified to RWD with wider tire in the front at is 330mm while car like Enzo FXX front tire is only 255mm or 245mm
But RWD are more likely to spin in corner if throttle is applied, will be harder to turn a AWD as will cause understeer
The reason AWD doesn't spin out that easily is because some percentage of power is transferred to...
