Greddy Emanage, Ultimate & V-Manage
EG6SiRT?
492
jinkl,
u know how much max boost can the std b16 map sensor take? if u cheat here n there i herd max is 1.1 to 1.2 bar? is it true?
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
www.ftzoneracing.com
learning to play with the tuning software wouldnt be the greatest deal
bt the thing is that , mostly all the tuners already do know or experience on
how the car really runs , what kind of sensors , wiring system and etc
these are all hard to be learned in a short time , summore every car has its own
wiring which would be unique from other cars , they could be running on MAP , MAF , MAS ... diffrent set of ingition coils , they triggering could be from CAS , crank angle , and so many more...
yeah... that's why some tuning places are well known for certain models only.
say; shop A good in tuning vtec turbo, shop B best for Nissans, shop C only good for Proton Rojak and the list go on.. seldom can get 1 tuner which is expert in all makes and models. you may be good in japanese cars.. but u may suck in building a good powerful alfa romeo
140dB
393
johor
yah man...
wtf. how bad can things be...
just popped a leak on my radiator, head gasket, noisy dshaft, and now clutch slip.
the pains of doubling engine torque
lanevo- like i said, get a good book, find out everything about ur engine bay. most hi po engine from the past two centuries use electronic fuel and ignition engine control, so it pays to read up some simple electronics. good luck.
eg6turbs- i dunno what the max the stock sensor can take. but i put an aquarium one way valve wif a 1/4 turn valve to bleed excess boost from the map sensor. put a tee to the line. it hasnt messed up the vacuum signals on my car so far, and is one of the cheapest mod i've done. i plan to change to a festo aluminium 1 way valve. brushed alu looks superb compared to the plastic fishtank valve, but uses leceh m5 pneumatic fittings and costs rm75 from the festo dealer.
EG6SiRT?
492
140db..
Thanks...but thats my main concern, so that it wont mess my vacuum, but worry not, coz i just got a fren who have aftermarket map sensor and willing to part with it!
wuts the best material for a turbo return hose be?? put away steel braided(no go)...
maybe silicone? or any other?
EG6SiRT?
492
anyway, sorry guys, should put that in other topic...
joe_mivec
195
PENANG
Nowadays how much for Emanage blue package? (Emanage + Installation + Injector harness + IGN harness + Dyno Tune). maybe wanna set a trip to KL next month to fine tune my engine performance, FC and AFR. And which shop have good reputable in this emanage tuning...?
jegvd
1,932
joe_mivec : You can go to RS impressive(puchong) for your dyno tuning coz the tuner Robyn..is really doing a great job for e-manage tuning which he can customise your E-manage with built-in turbo module if you driving a turbo car.In my experience after tuning my e-manage with a few tuners around KL area..i get more 20-30hp from Robyn's tuning compare to other tuners.So far, already 2 years with his tuning...my engine running well.Thanks to Robyn....
handsomeboy
228
bro jegvd, im planning to put e manage to my satria neo..heard its possible right now. but will do engine upgrade 1st like port n polish, hi cam n all.. when i wanna do, hope u can help me bro...
joe_mivec
195
PENANG
ok thanks..so it's RS impressive(puchong)....ur gain around 20-30hp for NA or Turbo? mine just NA only...so how much is that for all package? thanks...
Wajafly
159
Shah Alam
I used to go to N1 with my modified 4G18. He simply increase 3WHP only using newly installed emanage. WTF... then I went to Links. Increase another 12whp. So, Links are better than N1....
joe_mivec
195
PENANG
ya so Links better than N1...how much they charge u? is it include ignition harness and tuning?
D-IV
262
Who has Greddy E-manage on their OBD-0 b16a wired up??
Hi, any one of you guys are running Greddy E-manage ultimate on your b16a OBD-0 honda? I've been trying to figure out whats wrong with my car. Its throwing some error commands which i can't seem to figure out. Some error commands are like
1- unable to open crank.dat
2- unable to open afc_sw.dat
Greddy has poor customer support so i can;t ask them. Now i can't get the fuelling to go up when i tune the car.
wirafly
958
How emanage work
May I know how emanage work as piggyback to control the fuel? is it control the injector or it similar to SAFC which control air flow to cheat the ECU (correct me if I am wrong)?
Hello.......to all modification 'otai'2 & Drag GodFather:adore:..........
I really need your advise/help for recommend me to which shop/garrage that expert modified BREMBO 4POT front & BREMBO 2POT rear to my WAJA :hmmmm:.... More preferred any garrage located at northern side such as Perak,Penang,Kedah,Perlis if not any expert garrage also can. :D Really need help.....! Any advise,guided,foreman charge,costing are very welcome.......Thank you very much..... ! :wavey:
Maju Lah Sukan...
