engine hard to start when its hot
karhong
54
Hi guys...im driving a toyota ae111 or known as SEG with engine 4afe stock.
recently i found out that my car is hard to start when its hot...
like i part at convenient store to buy stuff,then when wanna back home,hard to start...
i already change the distributor,new plug cable and spark plug edi...
and somemore run diagnos to check got sensor broken anot...
and the problem is still there...can some1 tell me what is the problem?
when its hard to start, i can smell petrol smell... :(
i got phobia to stop my car now...
xtremeleo
3,247
464
does it crank when hot? crank but doesnt start? or crank, about to start but doesnt?
karhong
54
it does crank...but doesnt start nomatter how long i hold the key...so i need to close and pull the key out and try again for few times only to get start...after start,engine is like not stable...rpm oso wan drop like that...so i press oil to make rpm go up and only it stable at 1k rpm...
check plug white colour or brownish??
if white probably setting was lean...maybe fuel pump weak already?
or try adjusting ignition (via distributors or ecu)
guest
346
20
Kota Kinabalu
this thing is actually happens to me...i'm using civic 2005....in the morning can start easily...but after go shopping or yamca for a few minutes in the afternoon or even wanna stop for refueling....car cannot start...damn!!!....check to the mech and add some relay..it helps only for few days...problem still persist...last2 i check my battery...its 2008..hahaha...bought new battery and its all SETTLED!!!...maybe this problem vary for different cars...but y not check your battery first....
mines998
1,048
149
663
Starter too hot also can cause this problem my car also also same problem as you. When I go to pump petrol off the engine when want to start the cranking like battery want to dead after a while the 1 crank then start.
starwing11
178
overheated fuel pump also makes the car hard to start....
Jakk
403
84
Selangor
last time my car kena the same problem.
the culprit is the main relay.
hope it helps.
huakenny
LB Performance
9,126
240
Kota Kinabalu
for battery check, when u cranking...the starter cranking power strong or weak? strong = battery ok, weak = battery weak.
for fuel pump, some mech connect a fuel press meter at ur fuel line to check the pressure.
and make sure ur car petrol not always at 'E' level coz fuel pump easily get overheated when fuel level getting low in fuel tank... :)
The president of Fuji Heavy Industries, the parent company of Subaru, who together with Toyota, jointly developed a sports coupe together that is a spiritual successor to the iconic Toyota Corolla AE86, has let slip on a late 2011 launch for the car...
