I will drain and pump Ron 97 in woh!Ya ya.. Like my l5 setting that time Ron 97 my wife put Ron 95 for daily use, just found it last week, damn knocking...have to lower down the boost to drive...if don later plug coil toasted then
wont drain, just pocket got a hole only...I will drain and pump Ron 97 in woh!
The K3VET I've seen the fella welded an outlet from the oil sump pan near to the drain bolt.another thing before forgot, where will be the best place to get the oil from engine to turbine ya?
thanks...
ya ya, return back to oil sump pan but now looking for the best incoming from engine to turbine..The K3VET I've seen the fella welded an outlet from the oil sump pan near to the drain bolt.
