3SGTE ST215 into ANE11
wishturbo
47
7
1,508
whoa...very nice conversion..
i saw 1 half cut same like urs selling quite cheap, got abit gatal to squeeze this to my AE101..
Hehehe wait no further lol
3SGTE comes with how many displacements? can install to older TOYOTA models?
3S variant got 2 type, NA and turbo.
NA is 3SGE (dual vvti, normally ppl call beam engine) which can be found in altezza.
Turbo is 3SGTE which can be found in mr2, mrs, caldina and celica
Mostly 4 cyc straight chasis can fit this 3sgte
hi.u wan to sell ur half cut bonet?
Sorry bro, using the scoop temporary for puspakom inspection
yeehau86
Feb 10, 2007
2,856
2,425
can it fit into ZZE-122? (asking on behalf of Supra Fanatics) :rofl:
TRD.AE92
780
40
your mechanic working so fast~!
mamatAE111
301
52
Dream project. 3SGTE....
Still got my Power Timing belt for ST205 3SGTE, just to keep the dream alive.:rofl:
Dayline668
1,810
492
1,683
Mine share where is your workshop located..? Look like Pro work..
banzai
1,231
29
5,148
KL \ Ipoh
i see...are there ppl who swap these type of engines into older TOYOTAs such as 1979 corolla(KE70), and such? can go for endorsement??
Few years back there is still rare cases jpj endorses ke70 with SR20. nowadays it is impossible already. 1.3 to 2.0 is too much. safest is 4AGE into KE70. that shouldn't be a problem.
there are few project 3SGE into KE70. in subang usj there is one KE70 with 3SGE Beams. car juz started not long ago, but in tuning up process.
For documented transplant, you may search through this site for more info.
wishturbo
47
7
1,508
Day 16 - Dream
Mike trying to fit my 3 layers aluminum radiator.
My new Blitz Super Sounds Blow Off Valve - Anti Ah Beng SQV sound, removed for my own good
D1 Spec Oil Catch Tank, my previous tank gave to someone, segan nak mintak balik.
Custom made front bar with 5mm steel. Rumor said even cow can die instantly if got hit by this metal
This is what we called creativity. Or maybe technical problem? Who knows~
Everything packed up in there!
hi guys! ive been searching the web for forums like these that might help me with my questions about upgrading my proton wira engine.
I've been researching alot and here in the philippines we have several wira's but most of the cars here are mitsu lancer. some of lancers here that are the same with wira can change engine easily. will i be able to change my engine to 4g92 or 4g63 easily? will it be a bolt on upgrade? i noticed other wira's in malaysia can upgrade their engine the only...
