Pls suggest which engine should i choose
dcloo
1,784
17
kl
Got B18c GSR/Type R crank&rod ready to part out
just reach me a call at 012-2123802
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
team99ers.2.forumer.com
Can i use gsr crank on my 1.6 block? Where can i get 1.8 stroker kit...i see not many ppl selling.
technically, cannot into ur B16A. but can into B16B.
in theory, can. just need to measures which & wat rod u shld use...
btw, Dcloo just got stock in hand. this is very hot item...
deathzone
373
13
Kota Kinabalu
How would b16a with type r internals and 1.8 stroker kit perform compare to b18cr? :hmmmm:
p/s Just now i just test drive my fren's ek b16b with 1.8 crank...not bad also.:driver:
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
nobody try out b4, so, no answer at this moment...
mayb u can stick to ur fren's setup..
dcloo
1,784
17
kl
its easy and simple if you wan to put 1.8 kit into b16a just some custom piston/rod lenght either 1 you go its just same as toda/jun/tracy sports 1.8 kit
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
BC cheaper... ahhahaha...
eghadi
40
bro...which garage you want to do your mod....???normally sure over budget....i also mod my engine and the budget i ready around 5k....now.i heard according to my fren my cost now reaching 6k++ not including labour.....i use b20 + my own b16head...bearings....power belt....top set gasket....type r skrw if not mistaken.....engine mounting oso change coz koyak suda....and engine oil oso not to forget list it as cost...oso radiator change coz leak cant use anymore....radiator hose oso tukar....ayak....mati la ini mcm.....hah.....and injector use b18 type r...to save petrol....engineering head must count oso dont forget.....i want to ask all sifu is it reasonable rm6+ not including labour....:banghead::banghead::bawling:
deathzone
373
13
Kota Kinabalu
Bro jin, roughly how much is the price for the below mod? And which want more worth to mod? Is there any performance diff in these 2 mod? Which want can rev higher safely?
1. B18cr year2000 + b16b piston
2. B16b+ b18c gsr crank
I just convert my auto b16a to ek9 manual gearboxset and already spent more then rm5k + labour, rechipped ecu, manual cam and others.:banghead:
My mistake i should have take an ek9 healfcut instead of spending more on labour and shipping. :banghead:
Kobra
89
1,508
bro, u using b20b engine with b18c R injector?
what piston u r using? standard or after market piston? size?
have u go to dyno? minyak cukup x?
hornydrifter
837
90
3,028
KEY EL!
huhuhu...Honda forumer talking bout modding thier honda and their b's...hehehe...
Love it....
Got lot-sa cash..go for K's bro...hehehe...if budget..
5~6k..
Buy b16b head..intake skunk...with nice set of clutch..ok edy...+ emanage..
:smokin:
pencalat
805
19
JB
why dun u try to upgrading ur drivetrain rather than increase ur cc....
with ur $$$$ u can some shiok2 bgox what.... hehehe...
D-IV
262
Ofcourse the B20 will give more torque than the B18C (gsr or type r). But I will go with Jin's advice, use back the B16a head and swap the block to a B18C. Any extra money, get some cams and valve train components. The block can handle 8000rpm reliably in stock form and bear in mind that stress increases as your RPM increases regardless how well you build the engine. So rethink on how you'll be utilizing it.
Ofcourse all these should be tuned properly. Hondata S300 is my choice, I would ditch the e-manage idea. didn't work too well on OBD-1 vehicles. Not sure about OBD2 though.
eghadi
40
standard piston only....no dyno....and minyak x cukup....heheheh...now changed to h20 injector...ok la for daily use but still can shiok2 speeding and let other turbosss see my bumper....just imagine the power when vtec kicked in yo...now planing to change my auto tranny due to high torque....auto cant stand....
deathzone......hows ur manual tranny???:driver:
deathzone
373
13
Kota Kinabalu
Much more better then auto lo...smooth and better acceleration. I dun dare rev too high only till 8000rpm eventhough my ecu can rev more then 9000rpm cos engine only b16a stock. Need to retune my vafc this saturday after that i wanna test my top speed :driver:
The Marketplace Top Posts
anybody can tell me where can i tune my mivec and how much they will charge? thanks ...
