Hi All Vtec Sifu Daigor
Currently My B16a Auto Tranny Won't Start,I Has Been Check Fuel, Check Plug, Check Distributor & Even Check The ECU Every Things Is Good.The Engine Check Is Fine,Compression Ok.
Fews Days Ago Im Tangan Gatal Cuci My TrottleBody Using STP Carb Cleaner Spray To Claen My TrottleBody During The Cleaning Need To Main The Minyak Than Spray The Trottlebody At First Round Spray less than30sec The Engine Mati Is Normal Mah So I Just Countinue My Secound Round Spray Lah Start The Engine It Again Than Start Spray (Thats My Bad Dream Start)When Started Spray The Trottlebody It Explode WALANOIIIIIIAsap Putih Kluar Lah Macam Kite Isap Rokok Lah Macam Dunhill Kau Kau Kluar Dari Trottlebody!!!!Mampoiiii......
Than Try To Start It Again But It Won't Alive!!!!!I Start Check Here Check There Every Things Fine So I Try To Figure Out Why Got Smoke In The End The Fuel Injector Pecah Pulak Cume Dua Pecah Yang Lagi Dua Ok Gi:hmmmm:The 2 Injector Broken It Near To The Trottlebody Side So I Decide To Change All 4 Pcs Injector Amik Motor Honda Kap Aku Bawak Gi Kedai Potong BeliAku Dah Siap Pilih Empat2 Injector Cun Tu Suruh Dia Org Bungkus Kan Dan Bayar Pas Tu Balik Pasang:vroam:Done The Installation Of The Injector Try To Start But Jialat Won't Start,Try Almost 5min It Still DeadBattery Pon Dah Charge Full Same Jugak:hmmmm:Plug Also Change Brand New NGK G-Power!!!!
Than I Notice When I Masuk Gear To D4 Kete Macam Free Gear Takde Lock Heran Aku.
Pls Advice And Help Or Recommend A Workshop At Jb But Harge Mesti Ok Lah I Know Few VTEC Power Worksop In JB Harga Pon Vry Power Leh Hehehe
Thanks A Million
Terime Kasih Manyak2
Aku Gi Isap Rokok Dulu Lah Penah Aku Type Bukan Type-R Tau Typing Wakakakak
GOOD LUCK TO ME
Thanks A Million
GOOD LUCK TO ME
