The 4agze Forum
lilwhite
354
juz wondering...if i wanted 2 get an E-manage for my gze....do need 2 buy da map sensor and da additional injectors harness?
Bump: juz wondering...if i wanted 2 get an E-manage for my gze....do need 2 buy da map sensor and da additional injectors harness?
5115
Nobody
5,952
2,254
Re: 4agze forum
r u fred from Nats?
yes,u r in the rigth forum
Nats autoparts
411
20
yup
nah...
my supplier have 3set complete 4agze engine coming in
so anyone who wants to buy can contact me:nurse:
miriguy
887
20
anyone using 4age TVIS camshaft in their 4agze? pls share
Bump: anyone using 4age TVIS camshaft in their 4agze? pls share
corolla92levin
428
yup. i try install 4.but u have to settup the campulley nicely.so u will feel the power come in...
so far try b4 B18c type R kena with 1 car.
Bump:
my ecu has been modified with removal of speed/rpm cut.
Bump:
how many cc is the GSR injector? So meaning no change in socket as well?
bro if not mistaken gsr injector about 330cc.if not mistaken.u used back the original gsr injctor socket.ut must have the wiring.u attach with 4agze injctor wiring.so far using it.ok.but u must have any management for controling ur air n fuel together.
miriguy
887
20
where to get those camshafts?
stock injector is 365cc. what abt the additional injector? need to upgrade that also?
the 6k rpm loss still a mystery. its not a prob with the MAP sensor, voltage tested in emanage.
However after installing the SC14, i have not full rev it yet. the vacuum hose to the IC cannot stand the pressure and flatten the hose when the car starts. Making my hose breaks into small holes. gotta make steel pipe for the IC
2 Old 2 Rusty
1,987
66
1,648
Who kena ? You mean the B18c lost to the GZE ? Pls don't be mistaken, I'm not doubting your claim. It's just good news for Toyota fans when we hear that Toyota can beat Honda, that's all.:biggrin:
miriguy
887
20
i have successfully installed sc14 in my corolla. I have problem when revving high. The rubber hose from TB to IC looks like a balloon want to explode! I tried using good quality air hose and it didnt last me more than 15mins. Imagine the massive air that this SC is blowing. FYI, im still using stock IC
i guess its either i make a steel pipe to replace the rubber hose or FMIC (last choice). i just want to test and see if the Top IC can stand the heat as well as the air. I guess not. But the last owner used stock IC to drag.
Will the FMIC (VR4 IC) causes lagging?
BTW, im currently boosting 1.2 bar at 40% throttle. cant go full throttle coz my IC pipe wont let me
futeball
316
2
www.4aeoc.org
wah......1.2 bar.....sure honda will eat smoke....:biggrin:
miriguy
887
20
right now IC not yet complete. i will guess if everything works fine, i might be able to boost above 1.3 bar
futeball
316
2
www.4aeoc.org
if 1.2 bar, what's your hp?
corolla92levin
428
yuup...u can ask mr shahrulae101.yeah im using 4agze.1.1bar boost.175.98whp.dyno at amoil sunway.
if u want using xtra injector.u can.but u have set ur emanage to setting ur fuel consumptions...kalo tidak.u kayakan petrol stations...
miriguy
887
20
not sure abt hp, there is no dyno test in my area, unless i go up to Brunei
my engine is not complete yet, waiting for the steel pipe connecting my TB and IC inlet.
attached are pictures with SC14 installed
Similar threads   Forum
Revanus Introduction and Newbies
DR78 General Talk
News and Features
Y General Talk
A Introduction and Newbies
Wheel And Tyre
Car Modification
News and Features
J General Talk
News and Features
Wheel And Tyre
Toyota
Toyota
Toyota
Toyota
Toyota
  Similar Threads
DR78 General Talk
News and Features
Y General Talk
Wheel And Tyre
Car Modification
News and Features
J General Talk
News and Features
Wheel And Tyre
Toyota
Toyota
Toyota
Toyota
Toyota
Hi all,
Something bad happened just now on my way home, i have got no idea why out of sudden my gearbox got this squeeky sound and 'tak tak' sound while shifting gears. Does this mean that the gearbox is dead? I like this gearbox alot, still can save ar? If not ..
1. How much does 2nd hand 1.3 GLi gearbox cost? roughly?
2. Can I use 1.3 Carb gearbox?
3. Installation workmanship labour?
4. What should I do with the faulty gearbox, can I sell it away to some steel shop?
GT Auto later in...
