tyre r fly wheel
shiroitenshi
3,676
170
whats the old type-r flywheel made out of?
as I understand, the new type-r (EP3/DC5) is made out of chrome-molybdenum steel, which does give better throttle/acceleration response.
I don't think the material matters because it's all about the weight.
Low weight flywheels are a pain for a daily driver, but some do live with it.
as to why.. I think those that are using them now can better explain.
IVAN TAN
112
600... want it ka? hehe
bro, is it new? , u said is better than our ori b16a flywheel....... dont mind to let me know wats better ? any better respon compare to ori flywheel?
bro hattech, wats the market price for second hand/chop shop cond LSD ori B16a?,tthanz:_:
Vagabond
1,731
53
1,648
shiroitenshi:
what I meant is, that the chrome-molybdenum steel flywheel is supposedly lighter than the standard flywheel.
but having used it for a while, i don't really have any complaints about it.
....... what issues arise from a lightened flywheel for the daily driver?
IVAN TAN
112
normal b16a lsd from eg around 500-600
thanks siful hattech, how about different tyre r fly wheel and b16a ori fly wheel.
weight different ......... how about the respon after istall and test? ,tq
akuma
3,489
152
Kuantan
ligthened flywheel=less mass 2 rotate/move=better throttle response...
dis 1 4 sure.....
problem 4 daily driver=hafta rev slightly higher whn moving in stop go traffic.....rpm will drop faster n haf less torque during uphill climb......
dats abt dat i know coz mine is standard
Enthusiast
588
2
5,018
dis 1 4 sure.....
yeah rpm drop very fast.....its a pain when daily driving......have to make some effort to achieve a smooth and not jerky ride.......
shiroitenshi
3,676
170
my friend have one in his shop half cut. actually any performance different if compare to type r lsd? both 1-way right?[/QUOTE
One way.. maybe.. they're both helicals, but perhaps the R version is made stronger, hence the mounts are different.
Well the thing about LSDs are if someone has it.. it's usually only one unit, and since the thing runs on gears, god knows how worn it is already, after all, it's the inside gears that matter.
But 2.6-3.8K for new lsd.. hmm hard choice.. I could simply get a type R gearbox with that.. the lsd may or may not be worn.. but I get the ratios as well.
IVAN TAN
112
dis 1 4 sure.....
thanks for everyone sharing here, i think i undestand on this,
thanks again
akuma
3,489
152
Kuantan
hattech-v,
ok ok..come n open up my gearbox..dis time u wanna kira by nuts + bolts or d thread?ahhahaahahhaah...................
Enthusiast,
well,its still kinda subjective ler...coz most ppl i know dat uses Type R flywheel(ard 8kg,is it?or 5.xxkg,can't remember) and SPOON/VISION(4.3kg) sed its liveable.....once u get used 2 it,thn no problem..not dat hard 2 drive even in stop go traffic.its only whn u add in those super heavy duty clutch like OGURA or OS Giken(hattech-v KNOWS best!hheheheh)....thn u got a problem..hehehe
Hello All....
after much deliberation, i have decided to paint my car sumwhere in usj1 area. they have all the necessary equipments n enough experience as a painter..... as for the price, not as cheap as i hope it would be but it is based on my request also that they dont use cheap materials.... more or less i wanted mid-range to high-range....
original colour: burgundy by PPG, code p48 a0086
new color: based on same colour code but will bancuh with more black to achieve 40% darker...
