Aircond Compressor Draining Too Much Power?
RENESIS VIII
7,063
950
Ipoh
Same loh! If taking power off the engine, even though at boost you can save some energy by turning the compressor off......lol
Normally from what I heard about house air conditioners, they are rated at 1 or 1.5hp. If our car's compressor drains away 1 to 2hp, we can still feel the power loss although the amount is so low.
You did NOT just compare home aircon with car aircon..... they run on different systems even though concept the same. Apala
cvkit17
2,884
1,354
different term of horsepower. AC hp is cooling capacity.
loose_end
3,649
197
Malaysia
My 4G15 Auto 3 Speed, the problematic air con compressor significantly reduce the torque or speed by 40%. But after changing the air con compressor, I didn't face or feel the reduction anymore.
RENESIS VIII
7,063
950
Ipoh
That bad? Mine was not that bad yet but I might say the drain can be like maybe 10-20% of my car's power. It certainly did not feel as much as almost half.
40% die loh! how to drive take so much power away.......:bawling:
I'm very interested to get an FD2R, also the price just dropped. Above that I'm putting a side about RM20k for car mod. What am I looking at & what could I get from that kind of budget?
I don't need a track car & not going to spend too much. If needing topping up above the budget abit would be fine. I'm asking this before getting the car...
What I have is mind is NOT to change the major parts in FD2R. What comes in with the car should be good enough already. Just mod it to the limit that...
