DIY: Changing Myvi Disc Rotor... solves the judder problem when braking.
jerrysiow
407
146
Seremban
Shoji brand isn't that good IMHO. I bought a pair from sparepart shop before myvi 1.5 rotor (17mm) on RM140. Correct me on the size if i'm wrong. The rotor very fast wrap again paired with IMP platinum brake pads. Now using halfcut OEM myvi rotor.
@Dark bro, you install myvi 1.3L rotor (15mm) or new myvi rotor?
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Bro, its warp. I see, my Father's innova also Shoji.
Japanese brand, made in Malaysia?
jerrysiow
407
146
Seremban
Ya, Jap brand but made in tomyamland if not mistaken. The price is quite attractive as below RM150 per pair compare to OEM where you need to pay around RM550 per pair.
My VR with Shoji also. Have them quite long already, so far so good.....:driver:
it is quite weird when too many myvi suffer from disc problem.....
but the one at my house never have problem with the brake disc since 2006 up till now...just normal routine maintenance replacing the pads only... :hmmmm:
VTEC LoVeR
994
112
543
Kulim
You are consider the very lucky 1... kakaka... :biggrin:
Still very fat :p
But if its warped, doesn't it mean its out of shape?
When u skim, the surface will be flat but the overall shape is unevenly thin and thick?
Not necessary. Most of the time is the uneven wear of the brake pads against the disc rotor to a point when at high speed and you do a hard braking the going in and out causes the vibration.
I have seen many skimming jobs and I have not seen one that waves left and right when they rotate them. If that is the case probably cannot skim already....:driver:
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Ok thanks for the knowledge!
Hi Guys. Good Day.
Desperately need help.
PLS LOCATE my car TOYOTA CALDINA GT-FOUR SILVER WQB 1124.
I sold the car 18 month ago but no name transfer done and the bank is gonna filed me as NPL.
Sold thru Used Car Dealer EOA Automobile. The company now defunct/pending police...
