DIY: Changing Myvi Disc Rotor... solves the judder problem when braking.
jerrysiow
407
146
Seremban
Shoji brand isn't that good IMHO. I bought a pair from sparepart shop before myvi 1.5 rotor (17mm) on RM140. Correct me on the size if i'm wrong. The rotor very fast wrap again paired with IMP platinum brake pads. Now using halfcut OEM myvi rotor.
@Dark bro, you install myvi 1.3L rotor (15mm) or new myvi rotor?
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Bro, its warp. I see, my Father's innova also Shoji.
Japanese brand, made in Malaysia?
jerrysiow
407
146
Seremban
Ya, Jap brand but made in tomyamland if not mistaken. The price is quite attractive as below RM150 per pair compare to OEM where you need to pay around RM550 per pair.
My VR with Shoji also. Have them quite long already, so far so good.....:driver:
it is quite weird when too many myvi suffer from disc problem.....
but the one at my house never have problem with the brake disc since 2006 up till now...just normal routine maintenance replacing the pads only... :hmmmm:
VTEC LoVeR
994
112
543
Kulim
You are consider the very lucky 1... kakaka... :biggrin:
Still very fat :p
But if its warped, doesn't it mean its out of shape?
When u skim, the surface will be flat but the overall shape is unevenly thin and thick?
Not necessary. Most of the time is the uneven wear of the brake pads against the disc rotor to a point when at high speed and you do a hard braking the going in and out causes the vibration.
I have seen many skimming jobs and I have not seen one that waves left and right when they rotate them. If that is the case probably cannot skim already....:driver:
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Ok thanks for the knowledge!
The Marketplace Top Posts
Sime Darby Auto Italia Sdn Bhd has launched the new Alfa Romeo Giulietta in Malaysia and it graces our shores with a 1.4L TB MultiAir engine with a 6-speed Twin Clutch Transmission.
<!--more-->The new five-door hatchback Giulietta promises heaps of agility as well as comfort for your everyday commute. All that capability also comes with a EuroNCAP five-star rating with an overall score...
