I also not sure what is it, but will bring over let him see. So if i want to install the air valve in Jetta also can?Like in my Hyjndai using air flow sensor, I cheat it by letting air in from the other end direct into manifold...
Ah! is it, I did not know woh!:hmmmm:
No lah! what well known....
Your carb got sensor to adjust? I think the other screw that is hidden one to adjust the air....
Yes, Daihatsu Mounting from Japan then is costly. Now ori Daihatsu and Normal one almost same price. Price not much difference.I've heard you mentioned this before somewhere over here that Kelisa mounting is even more expensive than Wira. Why is so? Or is it because the mountings are imported from Japan?
BTW, how much does Wira engine mounting costs? My mechanic told me that mine should be replace already if I want.
You put unker VR on table already. Grandmaster in the country.
45-50 is way cheaper than Kelisa then. Thanks for the info, Danz.renesis, my perdana mouting MMC costs rm75 per pc, wira should be approx. rm40-50 per pc.
Perodua should have just manufacture it here for the sake of convenience and budget of their customers.Some poison.
https://www.youtube.com/watch?v=tUWrsiPAoos
posted edi bout my fish mounting, if u tell them wira owner the price the mouth surely drop1:0I don't know about Kancil and Kenari, but Kelisa mounts I've changed before and it's bloody expensive because of the subframe mounts and the engine mounts. Both need to be changed at the same time and that's roughly about RM800 for ori mounts from Perodua excluding workmanship. All in it'll be 1k+
In my case even though I DIY-ed, buying the mounts was 500+ and removing the damn mounts and engine and all was a super pain in the ass since the engine drops downwards. Need to use support bracing and all. Very very difficult job for a one man show with insufficient tools. If I had the dual stage hydraulic lifter in my house that would've made it easier. But then that would mean my house would be a full scale garage already.
VR4 MMC ones last time RM200 plus. Nowadays don't know from where RM90 plus so use first....hahahaharenesis, my perdana mouting MMC costs rm75 per pc, wira should be approx. rm40-50 per pc.
Jetta can I think, just ask Fong, he should know as he tried on many makes and model, so which work and don't he has better idea...I also not sure what is it, but will bring over let him see. So if i want to install the air valve in Jetta also can?
yup... guilty as charged... you oso?u working in hp ah bro?
Me wangan 110 km/h only..... not dare venture more since it'll be at 5k rpm and my suspensions kinda mismatch of ori L5 springs + proride heavy duty shocks (long stroke like original but hard like the sport variant)... kinda bouncy and twitchyNext time if I go MEX, if I here a kepish kepish kancil passing by, I will give way.
