ATF Temperature Sensor Install
hex999
378
57
stupidcar, try using lubegard platinum atf addictive, might solve your problem. It solved my cefiro's morning sickness which takes a second to shift into D, i dont know if it might solve your problem though. This product is worth every cent and so far i haven seen any bad reviews about it so far.
stupidcar
5,000 RPM
5,567
850
VR, SF and the gang intro-ed me as well but its not because I'm worried about the tranny.
Been running it for 2 years, over heated or not only God knows.
I would like to install because of the numbers haha. And also to know how its working.
AND also I'm fitting an ATF cooler so I wanna do it together.
As bro. hex mentioned, I spoke to a parallel importer of lubegurad and he did mention it helps to lubricate the gear box so it will run cooler also....:driver:
stupidcar
5,000 RPM
5,567
850
My ATF is dueing on another 10k. We TT everything lah. :biggrin:
10k should be fast now since I keep travelling from end to end of LDP lol.
How much is Lubeguard again?
I am not selling just can get on behalf. Will apps you if not kena delete...:biggrin:
if all hardcore, should have install a cooling fan for the ATF cooler.....Sure WOW factor one....:adore:
i got my atf cooler with fan :proud::driver: no worries of atf overheats now....but more on engine overheat i need to keep an eye on that water temp. meter :banghead: (spoiled rad fan but tak sempat to replace it yet)
http://www.zerotohundred.com/newfor...utomatic-gearbox-cooler-3.html#post1063647809
*in the attachment: i redo all the bracket and placement+replace with smaller fan (with intend to use the bigger fan for my bike radiator) :biggrin:
and pardon the sh1tty jasma radiator fan.....gonna get rid of it once i got enough moolah for "spal" high speed fan (or any better fan)
stupidcar
5,000 RPM
5,567
850
Want an engine oil cooler kit? haha
punk
360
76
Negeri Sembilan
I did my ATF change at 10k km.:biggrin:
gear change not smooth so i did that, so far ok dy.
The ATF oil like already running in 20k km when drain the oil out.
What ATF u r using?
I'm looking for ATF-XP3, couldnt find it. i already run my ATF change at 15000 km already.
Quite weird it doesnt show any rough gear change anymore.
What happened to the technical members of ZTH? :(
Ha? What you wanna know la? I think it's a pretty straight forward installation. But i'd use a grommet or whatever you call those things rather than epoxy a drilled bolt.
What ATF u r using?
SP3 or XP3?
20k is usually the limit for normal ATF. Fully syn maybe a bit longer.
stupidcar
5,000 RPM
5,567
850
What ATF u r using?
The normal OEM one. I forgot which name. Haha
Sent from my Lumia 925 using Tapatalk.
punk
360
76
Negeri Sembilan
SP3 or XP3?
XP3, the petronas ATF.
oh, should be proton sp3 la.
YYC
1,833
939
Maybe atf temp sensor is good idea. How do we know the atf cooler is working efficiently, no clog? If we can pick up the abnormal reading,costly GB problem can be reduced.
By the way why can't any temp gauge hook up to the ecu to get the reading instead of a custom sensor? GB boobies here, please enlighten me.
The Marketplace Top Posts
hey to all 4G1++ user
how can we increase the performance of 4g13 stock engine other than using the the stroker kit?
newbe here..:)
