upgrade for accord S84
choon meng
49
5
1,508
good day to all sifu, i have a 2000 accord 2.0 sohc accord. lately the gear box start to complain me. i think is time to chage it. but i have a idea to upgrade the half cut engine like h22a + mt . any good work shop to modify and which half cut is suitable for this chasis?
bien335
1,819
48
1,648
Johor Bahru
hai bro.
where's your location?
there are a few options to upgrade your CF9/0/1/2
CF4 SiR-T : F20B + T2T4 LSD
BB6 SiR: H22A
BB6 SiR S-Spec: H22A + LSD (red top, 220PS)
CL1 Euro R: H22A + T2W4 LSD (red top, 220PS)
All the above are OBD-II, manual.
If you want to retain the automatic (since your chassis is automatic), you can go for:
CF4 SiR: F20B (tiptronic)
BB6 SiR: H22A (tiptronic)
CH9 SiR: H23A (tiptronic)
you can opt for the OBD-I H22A's from either the BB1/4 Preludes or CD6/8/CF2 Accords. But none are tiptronic.
choon meng
49
5
1,508
thank you bien335, i'm in k.l. area. any wiring or engine mounting problem with half cut above? any workshop recommend?
choon meng
49
5
1,508
BAD NEWS ...
FROM THOSE PART DISASSEMBLE FROM BOTH CHASIS. IT IS NOTING MUCH ARE COMPATIBLE.
THE THING CAN USED FROM THE EURO R CAN USE IN S84 ARE VERY LITTLE. ONLY THE ENGINE, GEAR BOX DISC BRAKE SYSTEM..
OTHERS MAIN THING LIKE DRIVE SHAFT ALSO CAN NOT USE , MAYBE TO CUSTOM MADE FOR IT!!
ECU ALSO NOT USE, ELECTRIC POWER STEERING SYSTEM CAN NOT USE, SUSPENSION & UPPER LOWER ARM + KNUCKLE CAN NOT USE
CROSSMEMBER + STABILIZER BAR CAN NOT USE
DASH BOARD (OF COURSE) CAN NOT USE
RESTRUCTURE POWER STEERING PUMP..ETC ETC...:banghead:
pretender
14
7
1,503
BAD NEWS ...
Which halfcut model did you get?
ddv_nk12
1,228
236
PD
oic. i didnt know this. i thought its the same. i think its the same case as civic eg n civic ek. have u already bought the halfcut? if yes, what u plan to do now bro? any pics on the rebuild?
choon meng
49
5
1,508
it is totally different chasis. include the euro-r brake paddle also can not use!!! luckily the clutch paddle + pump still can fit in...
pretender
14
7
1,503
BAD NEWS ...
Its amazing that so many things are different, maybe u should come out with a list of 'what to do' if there is someone going for a project like urs. Photos of the buildup will help too.
The Marketplace Top Posts
1st time:
About a year ago, he parked it right opposite of his mother's apartment guardhouse. According to the guards, their view were obstructed when a van parked side by side with my cousin's GTi. When the van moved away, the GTi vanished into thin air just like a David Copperfield magic trick.
It seems that my cousin was a victim of a syndicate that goes around stealing the hatch lock of GTi and making a key from it. Then they replace it back hoping the owner didn't notice it was...
