Satria Neo Review: Second Impression
Tom
TIMETOATTACK
Satria Neo
Satria Neo: Second Impression
Images
: Tom
Words: Jason
Car: Eon Malaysia
Today, the keys to the Satria Neo were handed to me, and it’s just me and my Neo, a 1.3AT model, and a brief drive in the 1.6MT and 1.6AT variants. I believe to thoroughly review a car; it has to be just you and the car, and not having someone else in the car with you. You wouldn’t need to worry about the other person’s well being; or have someone disturb you when you are connecting with the car. You just let go all of your worries and drive the car to your heart’s content. While this is about the drive experience, I’d also be sharing with you how it feels to live with the Neo.
Getting in the car was easy enough, and after adjusting my seating position, I noticed how low the roof was, or, another way of looking at it was how high the seat was. Don’t get me wrong - visibility is excellent, but I can’t help but feel confined having so little headroom. Still, if our Flying Sikh can be doing stunts in the Neo, I think it can’t be that bad; he is one of the taller Malaysians after all.
With a quick turn of the key, the engine starts immediately, emitting a low rumble, almost inaudible. I wonder if that’s because the engine is refined, or the cabin is well insulated, but either way it is a good thing. While waiting for the car to warm-up, I was fiddling round and about the cabin. The air conditioning vents are rather fancy, though I would have preferred a straightforward vent design, but that’s not a big deal once you’re used to it. Moving down, the air condition controls are pretty straightforward, but I kept wondering what is the space next to each side of the controls is for. For me to put my Touch N Go card? My mobile phone? An odd location, but I guess it could work. Talking about space, I find the lack of it in the glove compartment; the manual and booklets that came with the car took almost half of the space and I hope it wasn’t there just to hold those 2 items.
The side mirrors had to be manually adjusted, which is rather disappointing in my opinion. It was rather difficult for me to reach the side mirror on the passenger side, let alone adjust it. Adjusting the backrest was also a challenge, as with the door closed, the door panel was simply too close to the seat, and the space in between was too narrow for my hand to reach the lever comfortably. On the same topic, the side pockets on the door panels were almost inaccessible with the doors closed. I’m wondering were the engineers at Proton having too much fun driving the car that they disregarded the ergonomics for the interior. I know I wouldn’t mind driving a stripped down Neo on a track, maybe that’s what they were thinking, every Satria Neo owner would strip it down anyway, why bother
From standstill, the car is sluggish; which I attribute to the lower displacement, automatic transmission as well as the high revving nature of the engine, where the powerband rises significantly at higher revs. Do keep in mind that I am driving a brand new car with barely 600KMs done on it. Flooring it didn’t help, or at least, not yet…2,000rpm…nothing…3,000rpm….i feel it coming …4,000rpm… hold on, the car is lurching forward …5,000rpm… the engine explodes to a roar all the way past 6,000rpm to redline! It was scary the first time I did it, as I was worried that the engine might fall apart, but after doing it a few times, I was enjoying myself, feeling the kick while getting an adrenaline rush as the roar of the engine escalates. I absolutely loved the automatic transmission as the shifts were smooth and fast. Cruising at 80km/h, I floored the pedal while I observed the tachometer and I noticed the transmission downshifting 2 speeds; acceleration was almost instantaneous and power delivery was fluid. No jerk due to shifting, no lag, and most importantly, no loss of fun. The transmission is definitely tuned to suit the high revving nature of the engine, almost like a match made in heaven. The brakes were responsive, and you may even find it sensitive if you’re not used to it. In my opinion, it’s more than sufficient to tame the Neo.
Driving a Satria Neo on the road certainly attracted a lot of attention. Every turn I take, I see heads turn, but I was pretty sure I had more fun than them while taking the turns. At lower speeds, the steering felt a little slow to respond, but once up to speed, it wasn’t an issue. I felt confident maneuvering corners as I entered familiar turns at speeds higher than I normally do, and flooring the pedal a little earlier than I usually do before the exit. And not once did the Neo let me down. My eyes see where I want to go; my mind envisions the path; my limb sends the command and the Neo takes me there. If I was asked to describe this with one word, it would be euphoric.
Having the engine mounted in the front and being a front wheel driven car, we’d expect it to exhibit signs of understeer. However, understeer wasn’t apparent, if it even did understeer at all. Not once did the Neo strayed away from the line I wanted to go; maybe I wasn’t pushing it enough, but I was certainly going as fast as I could on the road. Having driven every single mass produced Proton with Lotus inspired handling there is, I daresay the Neo is one of the best handling Proton to date. Holding its steering wheel however is a different story altogether, as it is simply too rough for extended use. I usually steer using one hand while cruising in urban areas, and it didn’t take long for my hand to hurt. Maybe the engineers at Proton figured that the steering wheel wouldn’t slip if they made it rougher, but in this case I think they overdid it because it feels like sandpaper.
The performance difference between the 1.3 and 1.6 variant is significant; with the 1.6MT being the most eager, while the 1.3AT being the most sluggish. I wouldn’t recommend the 1.3AT to our readers here at Zerotohundred.com, and that you’re better off with the 1.3MT. The best bang for the buck? The 1.6MT H-Line - where you get performance and safety, or the 1.6AT H-Line - a compromise between performance and convenience, matched together with safety. The H-Line comes highly recommended from me as the ABS, EBD and airbag is certainly instrumental in times of need; else other countries wouldn’t make it compulsory to have ABS and airbags in all cars. Unless you are taking the Satria Neo to the track (which I believe many would), I don’t see any reason why you should skimp on safety. For the road, it is definitely the Satria Neo H-Line.
There’s a Satria Neo to fit every lifestyle, and you just need to find one that suits you. Overall, the ergonomics leaves more to be desired and the cabin needs to be refined further, but remember that when driving a car, it’s the drive experience that counts, and the Satria Neo is high on drive, which makes up for its shortcomings.
Note: There are unconfirmed reports that test vehicles from Proton Edar are rev limited. All cars reviewed were provided by EON and there are no rev or speed limitations of any kind on them. To fully experience what the Neo has to offer, we recommend that you drop by an EON showroom near you"
For enquiries or test drives, please contact:
EON Berhad
Contact:
1-800-88-3003
Website:
http://www.eon.com.my
Sales Contact:
Randy Ong
019 334 2587
Rosli Johari
019 2800 333
Mohd Arif
012 630 6666
Ronny Low
019 336 4381
Link to part 1: http://www.zerotohundred.com/newforums/showthread.php?t=96083
Proton Satria Neo (On The Road in West Malaysia w/ Insurance)
1.3MT: RM43,500
1.3AT: RM46,500
1.6MT M-line: RM48,500
1.6AT M-line: RM51,500
1.6MT H-line: RM51,800
1.6AT H-line: RM54,800
Suggested monthly Installment structure from Eon Malaysia
EON Berhad
Contact:
1-800-88-3003
Website:
Sales Contact:
Randy Ong
019 334 2587
Rosli Johari
019 2800 333
Mohd Arif
012 630 6666
Ronny Low
019 336 4381
EDARAN OTOMOBIL NASIONAL BERHAD
BRANCH SHOWROOMS
BRANCH CONTACT PERSON
NO.CODELOCATIONADDRESSOFF TEL NO.FAX NO.MANAGER NAMEADMIN EXEC.NAME
1224PUDU91,93,95 JLN CHANGKAT THAMBI DOLLAH, 55100 KUALA LUMPUR.03-2141311103-21413932JOE LIMYONG PIK KUEN
2222AMPANGNO. 10A & 10B, PUSAT COMMERCIAL ARA AMPANG, JALAN AMPANG, 68000, SELANGOR03-4251088803-42510167AZIZUL MUSTAPHA
3227JLN CHAN SOW LINNO 188, JALAN SG BESI, 57100 KUALA LUMPUR03-9222363303-92212791ABDUL SAMAT SAMSUDINDAVID HWANG
4225CHERAS29, JLN MUTIARA RAYA, TMN MUTIARA BATU 6 JLN CHERAS 56000 K.LUMPUR.03-9130551103-91327116EDWARD CHOI CHONG YUENMOHD HAIZAM B IDRIS
5223OLD KLG ROAD79A & 79B, 3RD MILE, JALAN KELANG LAMA, 58200 KUALA LUMPUR.03-7981857703-79818613VINCENT N.K.TANAZLINA BTE YASSIN
6226KEPONGLOT 9818, PERSIARAN MOHAGANI, SEKSYEN 7, BANDAR SRI DAMANSARA, 52100 KEPONG, SELANGOR.03-6276340103-62767298MASCRABO CHINMAZWAN BIN RABLY
7201SS2NO 9 JALAN SS2/75, 47300, PETALING JAYA SELANGOR.03-7875812203-78744992MEOR ROSLI B MD AROFFMUHAMMAD HAZRUL BIN MUZAFAR
8202JALAN TEMPLERLOT 83, SEKSYEN 51/213 JALAN TEMPLER, 46050 PETALING JAYA,SELANGOR.03-7781624203-77816322LIM THEAN SUNALMINIZAM BIN ALI
9203KEMAJUANLOT 3-A JALAN KEMAJUAN 12/18, 46200 PETALING JAYA,SELANGOR.03-7956382203-79573249WILLIAM CHAN WAH SANGMOHD NADZERI B KASSIM
10204KLANGLOT 25 & 27, JALAN SATU, KAWASAN 16 BERKELEY TOWN CENTRE 41150 KLANG, SELANGOR.03-3342041103-33428879DAVID TEH BOON HOCKSAIFUL AMIR SHAHIDAN
11207BANTINGNO 40 JALAN BESAR 42700 BANTING, SELANGOR03-3181466703-31814678MOHD IBRAHIM MERICANADZWAN NIZAM B AHMAD
12208GLENMARIE & PSSEON HEAD OFFICE COMPLEX,JLN KERJAYA, SEKSYEN UTARA SATU, 40000 S.ALAM.03-7711221103-78036690MAT DAN HASSANCHOO CHUN KHUI
13331SEREMBANLOT 915, JALAN TUANKU ANTAH 70100 SEREMBAN.06-762915806-7627911MASKAMAL KHAN BIN M. ALIFONG TAT SIN
14332BAHAUNO. 39, TAMAN RIA, JALAN ROMPIN, 72100 BAHAU, NEGERI SEMBILAN06-454370006-4544700AZLAN THANABALAN B ADBULLAH
15321MALACCANO 3530 JLN BATU HAMPAR PERINGGIT 75320 MELAKA.06-283222506-2832121YAHAYA MAJID TAN JIUN KIAT
16307SEGAMATNO 42 & 43, JLN GENUANG KAMPUNG 85000 SEGAMAT, JOHOR.07-931818807-9319248ZAZALEE BIN ABU KASIM
17301J.BAHRU - INO 60 JLN LANGKASUKA, KAWASAN PERUSAHAAN DATO' ONN 80350 JOHOR BAHRU JOHOR.07-238819907-2388033CHEW AH BENGNORAMAN BIN TURIZAL
18302J.BAHRU - II NO 79 & 81, JLN ROSMERAH 2/2,TAMAN JOHOR JAYA,81100 JOHOR BAHRU, JOHOR.07-354991907-3545929MOHD RASYIDIN BIN NAWI
19304BATU PAHATNO 700 (LOT 13303) JALAN BUKIT PASIR MUKIM SIMPANG KANAN 83000 BATU PAHAT JOHOR.07-431551107-4319266ZULGHAFIR HAIRIAHMAD RIZAL B MOHD SHARIFF
20305MUARLOT 1462, JALAN BAKRI, 84000 MUAR, JOHOR DARUL TAKZIM06-951513006-9525081ISMAWI BIN SHAARI
21303KULAILOT 1151, JALAN KASTURI 36/41, INDAHPURA CAR CITY, 81000 KULAI, JOHOR07-663412207-6637228SYED MAZLAN SHAH
22306KLUANGNO 15, JALAN BINTANG SATU, TAMAN BINTANG, 86000 KLUANG JOHOR07-772310007-7723102LIM CHEE KHIANG
23101IPOH - ILOT 3893 JALAN TUNKU ABDUL RAHMAN, 30010 IPOH PERAK.05-506166605-5060666ABDUL WAHAB BIN MOHD NOORWONG WAY SIONG
24102IPOH - II NO 148, JALAN RAJA PERMAISURI BAINUN, 30250 IPOH, PERAK.05-255280505-2559555DOMINIC CHOW
25104SITIAWANLOT 29526 & 29527 BANDAR BARU SERI MANJUNG, DAERAH MANJUNG PERAK05-688587305-6881702OOI CHIN CHUAN
26105TELUK INTANNO 89, JLN CHANGKAT JONG,36000 TELOK INTAN, PERAK.05-621164205-6211642EDWARD JOHN A/L K AMBROSE
27103TAIPINGLOT P.T.790 BATU 2 1/2, JALAN SIMPANG,34000 TAIPING , PERAK 05-847388805-8473890WA JUN HENGSHAHRIL AMRI BIN RIDZUAN
28112GEORGETOWN -ILOT 1101, 1102, 1293 SEKSYEN 9W G.TOWN AT JALAN MAKLOOM 10150, SG. PINANG, PULAU PINANG.04-281956804-2829158SAIFFUDDIN B AZMIZAMRI BIN YAACOB
29115GEORGETOWN -IIGROUND FLOOR, BANGUNAN PERSATUAN MELAYU PULAU PINANG, 117 JALAN MACALISTER 10400 PENANG.04-226604404-2276314CHE OMAR B SAARI
30116BAYAN BARU NO 198, SG TIRAM, JALAN SULTAN AZLAN SHAH 11900 PULAU PINANG04-642385304-6424001YONG BENG KEATLOH TIAN CHUAN
31111BUTTERWORTHLOT 262 MUKIM 1, JALAN KIKIK TAMAN INDERAWASHI, 13700 PRAI PENANG04-390890004-3994224YAAFAR BUDINTAN JIT SENG
32114BKT MERTAJAM17 & 19 JLN MAJU KAMPONG BARU 14000 BUKIT MERTAJAM.04-539196604-5399133JALALUDDIN OMAR
33121ALOR SETARNO 210 JLN GANGSA MERGONG II, 05150 ALOR STAR KEDAH04-733818804-7319704NORWIN MOHD NORKALAI KUMAR PERIYASAMY
34122SG PETANIC25 & C26, LORONG 8, TMN SEJATI INDAH, 08000 SG PETANI KEDAH.04-431192404-4311411RIJALUDIN ISMAIL
35124LANGKAWILOT 3402, MUKIM KUAH JALAN PADANG GAONG 07000 PULAU LANGKAWI. KEDAH04-966611804-9666995JAMAARI B MAHTAR
36123KANGAR276 & 278 JALAN BARU 01000, KANGAR PERLIS04-976210204-9764104NASRUDDIN B SIDEK
37401KUANTANB4342 &B4344, JALAN BESERAH 25300 KUANTAN PAHANG.09-566613309-5665196LOW KIM HONGABDUL RAZAK B MOHAMAD DAUD
38404TEMERLOHLOT 339, JALAN KUANTAN 28000 TEMERLOH PAHANG.09-296116609-2963176MOHAMMED RAJAB B ITHNINMOHD AMIRUDDIN OSMAN
39403BENTONGNO TA-1 & TA-2, TAMAN ANGGERIK 28700 BENTONG PAHANG.09-222443309-2224446ONG YEW TEONG
40411K.TRENGGANU31-E/1, JALAN BKT KECHIL 21100 KUALA TRENGGANU, TRENGGANU.09-623341109-6233414ZAHARUDIN MAD AKHIR
41421KOTA BHARULOT 249-253, SECTION 25, LANGGAR JALAN SULTAN YAHYA PETRA 15200 KOTA BAHRU, KELANTAN.09-744946609-7449442MOHD YUSOFF MOHDFARAN B YUSOFF
42501KOTA KINABALU - IMILES 5 1/2,JLN TUARAN, INANAM 88806,KOTA KINABALU.088-421222088-421223KEN CHONG KEN KYUNGROWLAND PENGAI
43511KOTA KINABALU - IISHOP UNIT NO 2-0-10 & 2-1-10, API-API CENTRE, LRG API-API, JLN CENTREPOINT 88000 KOTA KINABALU, SABAH.088-223472088-233075MDM. CECILIA CHIA
44502TAWAUH & C BUILDING GROUND FLOOR NO 1229 JLN DUNLOP 91000 TAWAU.089-772398089-761513TAN CHIK HUNG
45503SANDAKANLOT 1, BLOCK A, BANDAR PASARAYA, MILE 4 , JALAN UTARA, 90000 SANDAKAN, SABAH089-271377089-273005CHONG TSUN VUILILIAN CHONG (AO)
46507LABUANLOT 1, JLN TUN MUSTAFA 87007 FT LABUAN087-415651087-415649BRIAN LEE
47504LAHAD DATUMDLD 3295, BLOCK 4, FAJAR CENTRE 91100 LAHAD DATU, SABAH.089-882694089-883695VICTOR LOO
48601KUCHING ILOT 1039, SECTION 66, K.T.L.D. JLN. KILANG, BINTAWA IND. ESTATE, 93450 KUCHING, SARAWAK.082-482811082-486816STEVEN BONGGARY QUEK KUAN YONH
49611KUCHING IINO 8, DESHON ROAD, 93100 KUCHING, SARAWAK.082-243561082-243563ABD RAHMAN B AHMAD
50604SIBUNO 25 B & C, LANANG ROAD,96000 SIBU SARAWAK.084-331337084-331369YEO PHUAY NGUANG
51603MIRILOT 860, JALAN KROKOP UTAMA, 98000 MIRI,SARAWAK.085-656996085-651331EDMUND TAN
52602BINTULULOT 704 BLOCK 31 LIGHT INDUSTRIAL ESTATE 2 1/2 MILE BINTULU-MIRI ROAD 97008 BINTULU.086-336001086-336036WILSON TEE
yeah..
as comparison among proton campro, neo or gen2 is better??
thumbs up for you tom!
I've tested both the 1.6 M/T and A/T. Of course the M/T is just responsive to drive and is my choice anytime but the A/T is equally kick ass with a relaxing drive if you want to. I've just ordered a 1.6M/T H-Line yesterday. It may take about 1.5 months to deliver. Hoping to get it earlier though.
Oh yes... Awesome pics Tom!!
The lack of interior space and storage compartment plus strange ergonomics will probably annoy the hell out of me on a daily basis. I'm impressed by its driving dynamics and build quality but ultimately, to save this car for me, it would have needed a spirited, cracking engine and unfortunately, it doesn't.
After reading the reviews, makes me feel regret for buying Wira SE coz the OTR price is almost the same but Satria has 1.6! Anyway, nice contrast to put the car in the junkyard for picture. Very creative! Good job Tom..
nice photo tom...
suitable wif da location..
is there anyone dat own gen2 and neo..?
plzz let us know da comparison...which is better..
creative location that blends with the car!
looks like proton has improved after all.. waiting to c the GTI version of it!
As usual, the pics are awesome and the report are way better than our local magazines.. great job guys..
i like the looks...but hate the built quality...besides,it is still a proton...
haha
yea cool pics
was wondering where's da location ya
can drivie there to shoot my car myself
was wondering izzit Proton's new design by putting da Exhaust at da middle juz like Savvy ?
bored to chose either left or right....
center save problems...
