does anyone know wat does high cam for???
can it be done to all car??
what will be the cost ???
what part will be involved???
lol very funny.nitrus said:Actually high cam can DIY .
The only parts will be involved is your car's roof.
Just need to buy any camera, digicam also can .. And drill it to stick onto your rooftop. The highest point of your car..
It'll be a high cam.
- lift the valve for a longer duration so you get more air into your engine at higher rpm thus increase power but sacrifice low end power since the air can flow back into the intake manifold because the valve opens for too long.detoaura said:does anyone know wat does high cam for???
if change puley only without changing camshaft, it is only stock cam with adjustable cam puleyWestCoast said:tumpang tanya sat..
if change cam pulley only didnt change camshaft will do hi cam? im really noob at this..so need help
changing the puley only lets you advance of retard the camshaft. Yes it does increase power but only at the rpm that you tune it for, and the rest of the rpm will suffer.WestCoast said:my car is a 4G93 standard engine in a putra
if i wana do hi cam wif changing only the cam pulleys can or not?
if change cam pulley only didnt change cam shaft can adjust till how many degrees? performance how? thx sifus!
you do not change the degree the cam open by just changing the puley. a stock 240 degree cam will always be 240 degree if you don't change it (because its solid metal stuff lol they don't change shape XD)WestCoast said:by changing cam pulley can do 272 degrees? wat brand good? aerospeed ok? im really interested at this cam things but im noob at it so need help.need change wat cam belt stuff??
check if the cam is female if so give her stilletos then adjust height already XD rofl jk jk..kob3bryant said:with adjustable cam pulley only can adjust the height of cam meh?
