water temp problem during idling
rockcity
hi guys....
need u guys opinion on this problem.
Few days back already change power fc from ralliart ecu and send for tuning and dyno. Regretly, no tuning can be done due to boost leaking at actuator. On the way back, my water tempt keep rising to 100 deg during idling and down to 85~90 if on the move. When i check on defi recorded 100 deg and boost at 1.7 bar (overboost previously maybe).The next day after tuning, still the same problem occurred and spotted fan will run only after 100 deg using power fc.
Any opinion how to rectified this problem? is it because of fan not blowing or because of over boosting that effect the gasket?
any suggestion for mechanic in kl for this problem?
thanks.
r u having STOCK radiator ? no bubble tank ? stock water thermostat ?
i suggest u change to 3 layers alu. radiator like koyo, change water thermostat as well, if got budget add on a bubble tank....last n foremost.....ON your fan FULL TIME :D
with dat kind of setup....u r set at 73 degrees most of the time when moving, stuck at traffic jam, max max aso not more than 80....hehehe in a way, your engine is always ready to tekan n go !!! remember turbo charge power depends on heat factor....too much heat will kill of your power n engine ;)
U R using L Jetro or D Jetro...if not mistaken...power FC got version with Fan Control...maybe just need to reset the water temp setting...
wei.....is normal larrrrr.......
for evo fan onli kick in at 95 above.....
went u driving it will drop to 85 or so.......thermostat open at 82 .
change to ralliart thermostat. it will open at 72.
dont worry .........it is save.....
Yes its normal for PFC. Fan will turn on at 98C. It only happens during idle so no worries.
PFC cannot control fan setting. You can only on and off using handheld.
The water temp correction is not for that so dont change the value.
Alu radiator wont help either, changing aftermarket thermostat will help.
There's no problem with your gasket or thermostat....
thanks guys for the input... problem solved already. add sensor for the fan to on earlier. went to ah kit workshop to rectified it.
thanks to ah kit and power garage oso other crew bobo, marzuki, other mloc members (lupa nama). mloc really brothers la.
ah kit,
you have to give us royalty for promoting your garage...just wondering why marzuki and bobo always hang around CP garage...they're doing part time job or what????hehehehe
ah kit,
Brothers maa ... tengah buat kreta for the MLOC Gymkhana ...:rofl::thefinger:
Bobo already a crew ??
