water at exhaust tip
xtorm
my engine is a 1.3l dohc, everytime i start my engine there water coming out of my exhaust, be it hot weather or cold weather. is this normal? good or bad?
im using a straight flow muffler.
it was bloody hot when i took these pics.
http://allyoucanupload.webshots.com/v/2002226362125273736
http://allyoucanupload.webshots.com/v/2002256899832269010
It's very normal to have water on exhaust tip...it means that everything is still running is moderate / good condition..
Chemical Lesson #1
When there is a combustion in your Combustion Chamber, Air(O2) + Petrol +sparks = Combustion.
and the composites from the combustion would be CO2 which is very dangerous and in a good and clean and complete combustion will composite some H2O(water)...and tats because when there is Oxygen(O2) there is water H20
so water is good
wad if i accidently spray water inside my muffler ?? my muffler is kinda big that type ... i scare it store much water inside adi
you spray exhaust inside or you pour water through your exhaust ..it all won;t effetc your engine whatsoever...
exhaust is to blow out...not suction..so whatever in there..won;t reach into the engine...so don;t worry about the water and all..
there might me no water in the tip but in the combustion chamber there is ma..
when there is a combustion there will be water until the engine is heated up and all water will just be as well vaporise as soon as they escape through the exhaust.
