The Importance of having a thermostat
Hi all..
I used to drive a rolla SE Limited with a supercharger engine..
and...i got rid of the lil thermostat thingie...my car worked perfectly fine...actually i find
that my car runs even better...no overheating problems at all...
Temperature stay pretty constant throughout...starting up in the mornings the water temp
would take a lil longer to reach normal operating temp...and highway high speed driving
would cause water temp to drop slightly...other than that...No problems at all...
But i do check my cooling system properly, basically i make sure there are no leaks in the
hoses and stuff...and i'm using a high pressure radiator cap..1.3 bar if i'm not mistaken.
All i'm trying to say is...in my honest opinion and experience...there's nothing wrong with
getting rid of the thermostat...engine temperature is lower which i guess preserves the
engine oil a lil..fans don't need to work as hard...due to natural cool air coming in as u r
driving...I happily drove it that way...be it street, track...up down genting...highways...until
it got blardy stolen...
I'm driving a frostie now...and as soon as my mech says that there's no electrical wirings
or wateva that would cause a engine check light to come on ..i'm gonna chuck that stupid
piece of metal away...:shades_smile:
Cheers all...
Thermostat is not stupid piece of metal and it is there for a purpose,not for fun,car manufacturer wont put it there for no reasons i think
i second that, considering all car manufacturer is trying to cut down cost so they can lower car selling price, yet they still put a thermostat in.
for my case for example, i dun think i can really do without a thermostat, because i have a habit of waking up 1 hour before class, and use half of that surfing zth first thing in the morning, and 20 min for breakfast and wash up, so that left me 10 min to comute 6km to university, where the last 3 km of them is slow traffic in rush hour so i have to make up time in the first 3km by driving hard. without a thermostat it would be a desaster as i don't let my car idle for more than 30 second after i drive off.
engine oil a lil
in fact it might be the other way around. yes your engine oil won't spoil because of overheating, but will spoil because of "underheating" if you could call it that. When engine is not hot enough, piston ring won't expand to the fullest, thus allowing combustion gas to go into the crank and spoil the engine oil due to chemical reaction(a sifu told me this at first, but i guess its common engineering knowledge), and in the end spoiling the engine itself.
driving
theorically this would be true, but then even with a thermostat, my car never got hot enough to use its fan when i cruise on a steady speed like maybe 80-90km/h, even when my whole radiator is blocked by the condensor. (yes i didn't turn on the aircond, but thats another story, i'm trying to say that the limited air that goes through the condensor is already enough to cool down the engine for normal driving.
if im not mistaken the thermostat is there to ensure that the engine is running at optimum temp,this is the temp where the engine preforms at its best. removing the thermostat will cause the engine to run cooler than it should. this will also result in high fc, am i right? pls correct me if im wrong
not sure about the high fc part, but yeah, thats the basic idea.
scoupe said:
hey extrem ny probs with jpj, after putting scoop?
havent had any problem, yet.. there is alwiz the possibility. u have to remember one thing bro, starlets air scoop is a low profile unit. like the S cooper's, u cant see the scoop from far or from beside the car. how does urs look like?
well my scoop is still in the process, but the guy is gonna cut the scoop from the ae 101 and cut my bonet and replace with that, so generaly its gonna look like the ae 101 bonet.
haiyo.. get the supercharger scoop that is used to clear the supercharger instead of drawing air in from some 1967 camaro dragster lar XD police see also cabut far far dun dare aproach.
bro this is my scoop. so far it did help with the temp problem. i went up till bout half then when i started to move it came down.
Write your reply...
