Temperature Issue
Accord80
96
3,008
Seattlewangsa
Driving a Myvi BOT an I have this problem. After driving for some long time (2 hour+++) and stop, the temperature is rising. But, the temp will going down after drive back. Same thing also happen when driving from home to office (around 4-5 days). FYI, the head has been PnP to the max, got alu radiatior and run without thermostat. The fan is in good condition. Went for pressure test, it shows okay. What does it mean? Do I need to install an oil cooler?
Accord80
96
3,008
Seattlewangsa
Ermm....just do it according to my mech. FYI, I'm still new to turbo coz playing NA for a long time. But since this is happened (overheating) I decided to put back and still monitoring. If someone with experience can help me with these...
judean
121
30
528
i noticed dat some ppl like to remove their themostat...
n normally their reason is so dat their engine wud always in a low temp condition...
can anyone clarify on this...?
logically n theoretically to me it seems like it can be done...
but juz like bro danzeterna said...
it's there for a reason rite...?
7,514
well...i suspect the aluminium rads not have enough cooling capacity....
p/s:copper rads better than some aluminium rads
Accord80
96
3,008
Seattlewangsa
Well, let's think from a negative side. Can it be the head warped?
turbolover
1,187
112
Petrol powered car needs to operate on an optimal operating temperature. Having the thermostat on all the time with the temp lower than usual will cause higher fuel consumption also.
huakenny
LB Performance
9,126
240
Kota Kinabalu
Thermostat valve open at certain temp degree to allows water to flow from engine to radiator........without thermostat mean ur water in cooling system is flowing all the time...that y the temp is low
If ur temp going up when idling(car x moving) and going down when moving....mostly is the fan issue....but not sure,u hv to double check d fan...add one more fan better
jeremylj
512
You mentioned tempreature will rise, how did you monitor it? External water tempreature meter? Or using your original meter? If external meter, how much is the range.? Have you checked the water level inside the radiator when cold? (Not the reserve tank)
15,390
Like what Pomen GTR said, Alu rads are not actually as efficient as copper rads. The only advantage alu has over copper is that it doesn't rust and most of the time aftermarket alu rads are made bigger so their surface area is larger. You're better off with a 2/3 layer copper rad imho.
Engine oils run at their optimum viscousity at 100 degrees celsius. So if you take out the thermostat it'll take the oil much longer to reach optimum viscousity and what does that mean? It means your engine is not getting the proper lubrication for a longer period of time. And why is that important? 90% of all engine damage occurs at cold startup. So if it's cold longer, more engine damage. We're not talking catestrophic breakdown here, just faster wear and tear of the piston rings, valves, bearings and generally most metal bits and pieces inside the engine.
In this BOT overheating case - can I ask if you are using oversized pistons? Or did you just plug and play K3VET low comp pistons? I suggest you change your radiator cap as well as the thermostat to an aftermarket thermostat. It sounds like it's not opening early enough to compensate for the larger heat the BOT is causing. Either that or your radiator is not getting enough air. Some Myvi bodykits are very restrictive and what some people do is drill holes in the front chassis bit that's blocking the radiator.
turbolover
1,187
112
Izso, What happens if one uses oversized piston? What are the consequence and how will it affect the temperature?
Slowboy
160
27
528
What ecu you are using? Certain aftermarket ecu have different setup for fan controller. If that is a prob, try to find an aftermarket fan controller
D7zul
2,697
848
Shah Alam
Thermostat is there for a reason..
and the reason is to control devices so that the system's temperature is maintained near a desired setpoint temperature
in other words.. the optimum temperature for an engine or anything else
read this
Thermostat - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Honeywell_round_thermostat.jpg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/4/4c/Honeywell_round_thermostat.jpg/220px-Honeywell_round_thermostat.jpg"@@AMEPARAM@@commons/thumb/4/4c/Honeywell_round_thermostat.jpg/220px-Honeywell_round_thermostat.jpg
15,390
Nothing's wrong la. Just depends on how much oversized. Cuz the alu block for the K3VE is very thin already so overboring it will make the pistons damn close to the water jacket and that in turn will heat up the water much quicker than usual.
Hello everyone!. As the title says, this was indeed a major challenge for me to restore the shine back to this 90's Mazda MX5 as the paint was heavily oxidized and neglected by the previous owner. This is by far, my longest detailing task to date. Here's how the car looked like upon arrival:
Notice the lack of gloss and shine?. The paint also appeared dull, weathered and pretty oxidized...
