RSM technical question
apexc
57
Klang Valley
what type of signal that RSM receive for the vechicle speed.
volt - 0volt to 5volt
mA - 4-20mA
pulse
answers will be very appreaciate.
thank u
apexc
57
Klang Valley
thanks very much.......any way to install it(RSM) in a sensor that giving output 0-5v
zaki
328
what are you trying to do actually?
if you are from electronics background, you might want to try pulse/frequency to voltage converter.
apexc
57
Klang Valley
no i would like to install the RSM to my car.....citroen.....from what i know my speed sensor will give output in volt....
sensor is a three wire sensor.....
1. ground
2. 5 volt reference from ECU
3. signal to ECU ( as i say above....signal might be in volt )
MR. Zaki any expereince in installing one in the conti cars....?
zaki
328
1. ground
i have tried to search in the net. i found that most of citroen speed sensors give pulse signal.
http://xantiaclub.net/hydractive2/
Speed sensor
The sensor is Hall effect based and produces 8 impulses per rotation, or approximately 5 impulses per meter traveled (this depends somewhat on tire size). It is located on the gearbox where the speedometer cable attaches, or in some versions, on the cable itself.
i have no experience installing one in the conti cars but as long as the signal is `readable', RSM will work
apexc
57
Klang Valley
thanks very much......sorry to border u so much.....
will try to ask in the forum more about it.....by the way i'm driving cit ZX 1.9i
very keen to install a RSM in my Babe....looks very nice although it has no function or to remove the speed limiter.....as i know....citroen cars doesn't has any speed limiter...
any problem occur during installation , can i contact u MR ZAKI.....???
apexc
57
Klang Valley
this is what i get through my search......from a source that i really can trust(not on the)
vehicle speed sensor
Hall effect type(8 signal per revolution).the sensor inform the ECU of the road speed of the vehicle. supplied with 12v , it produces a periodical tooth shaped signal whose amplitude is proportional to the vehicle speed.
diagram is as below.....
three pins for the speed sensor
1. 12v
2. ground
3. 6v when vehicle is in motion
so from what i understand from above....the third wire will send 6v output n aslo a asquare wave as describe above.
MR ZAKI the wire i should tap to the RSM is the third wire, am i right. i have the RSM with me right now....i m scared to try , scared anything happen to the RSM(friend's RSM)
one more question, what should set for the pulse setting? should i set to 8P?
zaki
328
no 1 & 2 is power and ground. the 3rd wire is the signal. regardless of how many volts it gives, the signal will always be on-off-on-off-on-off. if that so, the 3rd wire is the one that should be wired to the RSM's speed wire.
On the pulse settings you can start with 8pulse, if you want to make the car `looks' faster use lower value :) sometimes you need to trial n error for the settings if you don't have data.
apexc
57
Klang Valley
thanks MR ZAKI......already install n tested....it works.....
i just need the manual right now for setting......what u get from the net is the older version one.....not the one like mine....mine is the blue screen one....do u hav it...?
my mail [email protected]
apexc
57
Klang Valley
both the document u gave i already hav it......the manual is for the 4 buttons one right....mine is the blue screen n only one big round button that can moves left right up down n select is push the whole round button....
this is the one i have
apexc
57
Klang Valley
thank u MR ZAKI.......
apexc
57
Klang Valley
wrong speed sensor wire tapped .......
rorytate
4,417
hi apexc....
well, i've tried on that as well....
and installed at N1. Care to assist?
1: where is the speed sensor wire? if according to apexi pdf, there's 2 version and on that 2 version there's 2 different place to tap in each pdf...i've tried both\
2: where is the speed sensor? could it be the speed sensor kong already?
lancer meter console on a gsr-wira
apexc
57
Klang Valley
aaa.......will try to help....not so terror.....
as u install at N1 i think it will work....N1 sunway right.....?
the wire is at the ECU.....from the pdf file u can see it......near the rpm wire.....
speed sensor normally is located at the gearbox....where the drive shafts is insert...
this is what i can explain......more details hav to wait for MR ZAKI.....
ftzone
full throttle zone
5,339
141
Penang, Prai
www.ftzoneracing.com
rorytate.. refer to the wiring diagram (GSR) i attach. Also check if your RSM grounding is correct. If not try borrow pivot speed meter and test if your speed signal is ok or not. The other suspect is that the wiring is not connected securely with your meter cluster. Loose connection may have an effect on your speed signal. The other suspect is the meter cluster itself. Very unlikely the speed sensor failed while your meter cluster still can show u speed readings. Gdluck.
Guys, Repsol and Pennzoil Carnival sales on from 25th to 28th November 2015.
If you need engine oil, see can get something cheap from there....
https://www.facebook.com/events/151...gular&feed_story_type=263&action_history=null
Just sharing with members.......:driver:
