- Joined
- Apr 18, 2006
- Messages
- 3,677
- Points
- 1,663
Okay, I've researched this before asking, but there are hitches to each approach that I'm going to try. Simplified, here's what I'm doing.
The task:
Removing the soundproofing material off the floorpan, remove all rust spots, and get the interior resprayed, and finally replace the ori soundproofing material with aftermarket ones, (currently looking at 'brown bread' solution, although dynamat would still not break the budget), then lay out a fresh black carpet off an EG9.
NOT REPLACING the soundproofing material is not an option, as the previous owner did some stupid ICE wiring, and burnt some of the material black and deformed it when it shortcircuited on him.
The problem:
Those soundproofing material on the floor is super hard to remove cleanly.
Current ideas:
a) use dry ice and acetone to freeze the thing into smithereens, then remove them piece by piece
b) burn it off
c) ask zth members how they previously removed thiers (if they did before)
The question:
I'm seriously considering the honda-tech approach (choice a) but
I have no idea where to source the chemicals in Malaysia... If zth members know (maybe due to their occupation?) then help a fellow zth'er out.
If you have attempted this before, and successfully did it.. I'd like to know how you did it.
Thanks for any help you guys can offer.
The task:
The problem:
Current ideas:
b) burn it off
The question:
