Radiator Leaking
ken12292703
Drives a shopping cart...
SoMeWhErE
Hello brothers and sisters, please help by giving comments and opinions.
My radiator is leaking heavily. Have to top up every 3 days. Until today, i have found out the cause of it. Please look at the attached pictures. Please give ways to tackle this problem as well. Thank you so much.:cry_smile:
where exactly are the leak ? at the gasket or crack at the upper part ?
if crack & the upper part ar metal can send for welding or might as well change it or replace the gasket.
most shop can do this, even they can weld the core if its leaking
There are green green coolant fluid around the top radiator casing. It means that can change the gasket? Thanks for the comments. I really hope it can be saved.
Write your reply...
