Hi there, this is my first post. Just joined to learn more.
I'm hoping u guys can help me comprehend a little bit more about ICE.
Assuming these are the specs for an AMP:
4 X 70W @ 4 Ohms
4 X 100W @ 2 Ohms
2 X 200W @ 4 Ohms (Bridged)
2 Ohm stable
And these are for the SUB:
RMS 180W
MAX 250W
Impedance 4 Ohms, SVC
These are the few doubts I currently have:
1) If CH1 & CH2 of AMP goes to FRONT COMPONENT LEFT & RIGHT. CH3 & CH4 is bridged to SUB. How much power is going into the SUB? Is it 200W @ 4 Ohms? Cuz I believe when the AMP is bridged, it will be 2 Ohms, does this means 400W into the SUB?
2) The SUB's impedance is 4 Ohms. The bridged AMP is 2 Ohms. Any harm? Or what will happen?
3) Alternatively, is it possible to run CH3 & CH4 of the AMP at 4 Ohms? I think for that the SUB goes straight into either channel instead of bridged, but then it will be imbalanced. Any advise?
4) The AMP has 2 pairs of RCA inputs. If the HU packs only 1 pair of RCA outputs, is it the norm to use a Y-cable to split the output in order to connect to the 2 inputs? HU Left -> AMP CH1 & 3, HU Right -> CH2 & 4?
5) For HUs with 3 pairs of RCA outputs, FRONT/REAR/SUB, is the connection going to be like this: FRONT -> CH1 & 2, SUB -> CH3 & 4, ignore REAR?
Please advise.
Thanking u guys in advance.
4 X 70W @ 4 Ohms
4 X 100W @ 2 Ohms
2 Ohm stable
RMS 180W
MAX 250W
Please advise.
