if the existing car already got the airbag connection wire...it should be easy...PNP like others mentioned...
if not mistake, there's a screw below the levin steering...take it out...
peel out the steering middle plastic section...you'll see on big screw...if not mistaken size 22'
if you have the tyre wrench opener, the cross type...you can use that...loosen and take out the screw...
rock the old steering, left n right, up n down...jiggle it allowing it to slide out of the shaft...
once done, put it your new levin steering in reverse process ...
all the best and good luck...
