nommiey
From Facebook
- Joined
- Apr 12, 2011
- Messages
- 58
- Points
- 508
Hi Nom,
I know exactly what you what, you want your car to be zippy at low RPM...right?
Veloc is right, heres what I did on my car
1) Iridium Spark plug rm50/pc or so
2) Change plug cable to NEW ones but not those expensive once RM1XX will do.
3) Clean the Throttle Body
4) Change the Fuel Pump to 4ageBT/3SGE fuel pump and install a Fuel regulator at fuel rail(set it at 40psi)
5) Replace the heavy rim with light ones taiwan 15"6.5jj +38 offset
6) Change the Exhaust piping to 2.3" piping, change the mid box with a bullet, End muffler with a standard Levin Ae111 muffler.
7) Change air filter with K&N filter
thats about it, now the car response is better than when I had a 1.3L engine.
5) Replace the heavy rim with light ones taiwan 15"6.5jj +38 offset- has been done.
but the 4) Change the Fuel Pump to 4ageBT/3SGE fuel pump and install a Fuel regulator at fuel rail(set it at 40psi) The fuel pump did not come with half cut?
now I understand. but 1 more thing to ask is that when I push alot of gas to overtake,
