I think RS should be from Mitsu Libero GT model - wagon
GENERAL
Body type Wagon
Drive FULL 4WD
Transmission Advance 4 speed ELC full automatic
Displacement, cc 1834
Frame E-CD5W-LRGF
ENGINE
Engine model 4G93T (turbo)
Max.power (Net), kw(PS)/rpm 205 ps (150.78 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 28.0 kg*m (274.59 N*m) / 3000 rpm
Power density 6.2
Engine type Serial 4 cylinder DOHC16 valve IC turbo
Engine information
Fuel system ECI multiple (electrically controlled gasoline injection)
Turbocharger Turbo with intercooler
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 9
Bore, mm 81
Stroke, mm 89
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.6
Fuel consumption at 60 km/h, l/100km
OR
Mitsubishi / Lancer / 1994 / Modification RS (order production car) specs
GENERAL
Body type Sedan
Drive FULL 4WD
Transmission Advanced 5 speed manual
Frame E-CD5A-SNDF
Price of new car, thousands yen (Tokyo area) 1698 (~$14100)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4270 x 1680 x 1395
Interior dimensions (LxWxH), mm 1805 x 1400 x 1160
Wheel base, mm 2500
Treads (F/R), mm 1450 / 1460
Ground clearance, mm 150
Curb vehicle weight, kg 1130
Gross vehicle weight, kg
Seating capacity, persons 5
Doors number 4
Min.turning radius, m 5.1
Fuel tank capacity, l 50
ENGINE
Power density 5.51
Engine type Water cooling serial 4 cylinder DOHC16 valve IC turbo
Engine information
Compression ratio 8.5
Bore, mm 81
Stroke, mm 89
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.1
any diff ? I'm seeing only the comp. ratio are diff & bhp 180 & 210 ?
