- Joined
- Oct 27, 2004
- Messages
- 218
- Points
- 3,016
What is the setting of a BOV? How do i know what level should i set? Is there a guide to set?
Thanks.
Thanks.
in my case, i turn it to the softest. even then below 1 bar, no bov sound. not complaining though, using greddy type-r hehehextremeleo said:as for me, i tighten it to the max and drive around. and keep on loosing the spring until the turbine doesnt emit the chirping sound when off throttle.
khoyos, by doin what u described, ur bov will actually vent boost even on acceleration. ive tried it, but if its okie for ur ride, den maybe dis blacktop guy shud go ur way. its more simple :)
MitonCT26 said:what is BOV ah? can eat one ah? how it look like?
is it the one can get many many sound when off throttle wan izit?
i thought u dont know what is blowoff valve :PMitonCT26 said:eh?
you dont have to remove the vacuum hose. did you rev up the engine and let it drop to idle during setting or not?
you should set the setting to the softest...then ram the revs up and let it idle. if wanna mati engine, tighten by half round. then rev up the engine again. do until the engine is able to idle during free rev. then switch on aircond and rev again. if still wanna mati engine tighten somore.
how come you can adjust till screw come out one...heheheh...
assuming that ur bov is properly adjusted, then it must be the gasket to the blowoff valve. try using a gasket sealant.Raja_Mongkut said:duno wats wrong.. after pasang IC n BOV(type S) my car idling not stable edi... rpm needle will fluctuate occasionally.
wats the prob? some ppl say the ECU haven learn the setting, some ppl say got leak somewhere...
also when rev up high during idle(3-4k), rpm will drop until about 450rpm then come back up.. but BOV tarak lepas angin punyer suara lagi.
wat seems to be the prob?
