P pleezn Known Member Senior Member Joined May 3, 2005 Messages 294 Points 3,016 Aug 24, 2006 #1 what is the diameter for Mivec v6 (fto) tb?. . normal mivec is 60mm. .thanks in advance.:_:
P pleezn Known Member Senior Member Joined May 3, 2005 Messages 294 Points 3,016 Aug 25, 2006 #2 if any1 know pls reply.thanks
B boyzone 2,000 RPM Senior Member Joined Mar 13, 2005 Messages 2,668 Points 5,148 Aug 26, 2006 #3 Should be in 60mm also.
P pleezn Known Member Senior Member Joined May 3, 2005 Messages 294 Points 3,016 Aug 26, 2006 #4 i thought v6 should be bigger. . hurm. .i oso donno how big. . normal 60mm mivec tb maximum can bored is 64mm. boyzone, u use wat engine?
B boyzone 2,000 RPM Senior Member Joined Mar 13, 2005 Messages 2,668 Points 5,148 Aug 28, 2006 #5 Mivec ...
