Depending on how u use ur tap r engine. If u only put it at home and come out to show during gathering or drag once in a blue moon, then u can use the motul mineral. Change at 10,000km. If u drive more than 50km daily, and frequents track days and drags, then shud use redline or kaaz. Can change it between 15000-20000km. Heard of the new motul ff type 2 @ RM200 but dunno how good. But end of the day, no point spending money on things that u don't really need it. Motul mineral's fine if u're on a budget.Originally posted by aja@Apr 12 2005, 16:15
Any utmost recommended brand for Honda Type R engine?. I plan to use Motul 90aT (mineral base). It's ok? Any other recommendations?. TQ
[snapback]890437[/snapback]
Sometimes it may not be only the gearbox oil that's causing difficulty in engaging gears. Other potential problems are : clutch, clutch pump, clutch oil, synchro, or just a gearbox that requires cleaning and servicing. The vtec's have a potential to rev till 10k rpm (some1 told me he did that but i didn't do that :P ), so imagine the spinning parts that are subjected to this kinda speeds i'm sure it's scary.Originally posted by wfei@Apr 14 2005, 21:11
Hi coldfish...
Glad to hear that I am not the only one experiencing it. I find it difficult to engage in 1st gear and it grinds some times when I change gears.
I'm using B18CR 4.785FD and Motul but not sure what range is it but I know it is Motul.
Wonder if anyone else experience this?
[snapback]898076[/snapback]
B ko,Originally posted by KillerB@Apr 15 2005, 13:18
By the way, the newer model type r b16b/b18cR gearboxes have stronger synchros compared to the older ones.
[snapback]900035[/snapback]
B ko,Originally posted by BlackHD+Apr 16 2005, 05:17 --><div class='quotetop'>QUOTE(BlackHD @ Apr 16 2005, 05:17 )</div><div class='quotemain'><!--QuoteBegin-KillerB@Apr 15 2005, 13:18
