JB New Section........ Part 4.....
Next...........................[FONT=Arial, Helvetica, sans-serif][SIZE=+2]E6X Fuel & Ignition Computer[/SIZE][/FONT]
The HALTECH E6X is a powerful "real-time" programmable fuel injection and ignition system computer designed to control most ignition type engines. Whether 1-6, 8, 10 or 12 cylinders, 1-2 rotors, naturally aspirated, turbocharged or supercharged, the HALTECH E6X can control it.
The E6X System optimises engine performance through the following capabilities:
  • Ignition timing control
  • Fuel control
  • Idle speed control
  • Closed loop
The E6X is much more than a programmable fuel injection computer - it provides logging of engine data and allows access in real time to maximise performance and trouble-shoot problems in a vehicle while running.
Typical Applications:
  • Control of fuel injection on modified engines
  • Conversion from carburetion to fuel injection FONT]
    [*]Race and rally applications of all description
    [*]Design and development purposes
    [*]Educational use by universities and technical colleges
    [*]Original equipment in cars and motorcycles.
The patented HALTECH system of programming virtually eliminates the input of numbers. You simply manipulate bar graphs by pressing arrows keys on the attached PC running Haltech Programming software. Manipulating the bars allows you to increase or decrease the amount of fuel delivered or ignition advance at that particular RPM and load point. The process is repeated for all load points in each rpm range.
Ignition timing is precisely mapped through the RPM range so that the exact timing required to obtain optimum performance is applied in every RPM and load range.
The E6X Short Kit includes:
ECU Programmable Computer, Programming Cable, Short Wire Harness OR Patch Loom, Programming CD, Instruction Manual on CD and Haltech Stickers.RRP: $1395 AUDhttp://www.haltechstore.com/Kits.aspx http://www.haltech.com/images/e6x.jpg
[FONT=Arial, Helvetica, sans-serif][SIZE=+2]The E8 Series[/SIZE][/FONT]
The Haltech E8 is packed with more features than any ECU in its class by more than just a quarter mile. The all new E8 performance ECU is for those who are on a budget and need full sequential control for their engine.
The Haltech E8 ECU is an ECU capable of controlling sequential injection on 2 and 4 cylinder with semi sequential 6 and 8 cylinder applications. With 8 channels capable of controlling injection and ignition duties, the E8 can support most modern engines with multi-coil ignition systems, as well as conventional distributor ignition systems.In addition to controlling fuel and spark, the E8 can control various auxiliary engine functions.
  • Stepper motor and BAC/IAC closed loop Idle Control
  • Closed loop boost control
  • Soft cut rev limiter
  • Tuning via TPS with Manifold pressure correction - Ideal for those multi-throttle body turbo cars such as, GTiR Pulsars and GTR Skylines. COLOR]
    [*]O2 sensor closed loop mixture control
    [*]32x32 mapping structure
    [*]On board data logging (up to 200 samples per second)
    [*]User definable mapping points
    [*]Numerous correction maps to ensure smooth drivability under varying operating conditions
    [*]Windows Software
    [*]The ability to calibrate just about any sensor for OEM applications and of course all the
    usual outputs you would expect to find in a Haltech engine management system.
Click here to read more about the latest Halwin software used to program the E8 ECU.
  • Race and rally applications of all description
  • Design and development purposes
  • Educational use by universities and technical colleges
  • Original equipment in cars and motorcycles
The E8 Flying Lead Kit includes:
ECU Programmable Computer, Main Wiring Harness, 3 Power Relays, Programming Cable, Fuse Block Assembly on Harness, Programming CD, Instruction Manual (on CD), Haltech Stickers.RRP: $1795 AUDhttp://www.haltechstore.com/Kits.aspxE8 OPTIONAL EXTRA - Haltech Wideband Lambda Sensor Controller http://www.haltech.com/images/e8.jpghttp://www.haltech.com/images/1x1GrayPixel.gif
E8 PDF Specification Sheet
http://www.haltech.com/images/buy_now.gif
Optional E8 Accessories:
[FONT=Arial, Helvetica, sans-serif][SIZE=+2]MY MISTAKE. FUCK E8, U NEED THIS....!!
[/SIZE][/FONT]
[FONT=Arial, Helvetica, sans-serif][SIZE=+2][/SIZE][/FONT]
[FONT=Arial, Helvetica, sans-serif][SIZE=+2]The E11v2 Series[/SIZE][/FONT]
The Haltech E11v2 ECU is an ECU capable of controlling sequential injection on 4,5,6,8 and 10 cylinder applications. With 14 channels capable of controlling injection and ignition duties, the E11v2 can support most modern engines with multi-coil ignition systems, as well as conventional distributor ignition systems.In addition to controlling fuel and spark, the E11v2 can control various auxiliary engine functions such as:
  • Closed loop boost
  • O2 sensor closed loop mixture control
  • On board data logging (up to 200 samples per second)
  • User definable mapping points
  • Numerous correction maps to ensure smooth drivability under varying operating conditions Windows Software
Click here to read more about the latest Halwin software used to program the E11v2 ECU.
The E11v2 Flying Lead Kit includes:
ECU Programmable Computer, Flying Lead* Milspec type Main Wiring Harness, 3 power relays, Programming Cable, Fuse Block Assembly on Harness, Programming CD, Instruction Manual (on CD) and Haltech StickersRRP: from $2275 AUDhttp://www.haltechstore.com/Kits.aspxE11v2 OPTIONAL EXTRA - Haltech Wideband Lambda Sensor Controller http://www.haltech.com/images/e11v2.jpghttp://www.haltech.com/images/1x1GrayPixel.gif
Click HERE to download the E11v2 PDF Specification Sheet
Optional E11v2 Accessories:
tykiasu,
i think u can change to kiasi also. If mersing really so dangerous, why is everyone still come back in 1 piece and the car is in intact condition after so many trips? In fact, for the 3 unfortunated members case was all happen in City road. So wat talking you?
hello frank, cruise ok la. but to run on it, i kiasu and kiasi lo.
WET YET...!!!????
LS1 Ignition Coil
A high energy single coil with 'built-in igniter'. For use with wasted spark and direct fire application.
http://www.haltech.com/images/ign_coil1.jpgRRP: $95.00 AUD http://www.haltechstore.com/Extras.aspx
now this is why i say Haltech more superior thn microtech..
[FONT=Arial, Helvetica, sans-serif][SIZE=+2]Haltech MXL Dash[/SIZE][/FONT]
The Haltech MXL Dash is a powerful, professional and high-tech gauge which allows the user to sample and display a large number of parameters. The Haltech MXL Dash has a bright backlight wide display and a high speed USB data download to PC, which allows data to be analysed using the powerful Race Studio 2 software. Haltech MXL STREET
Haltech MXL TRACK will assist you in analysing and optimising your vehicle’s performance. Featuring 1 RPM input, 1 wheel speed input, 6 configurable alarm leds, 10 fully configurable shift lights, 128kb of internal memory, 8 configurable channels, the Haltech MXL STREET is what you are searching for. Haltech MXL TRACK
If you’re a driver, aimin
g to your best lap, you will find in the Haltech MXL TRACK a valuable help to analyse and optimise both you and your vehicle’s performances. Featuring 1 RPM input, 1 wheel speed input, 6 configurable alarm leds, 10 fully configurable shift lights, gear number display, internat lateral G sensor, 8 Megabytes of internal memory, 8 configurable channels, kit’s sensors and infrared transmitters and receivers. Haltech MXL TRACK is what you are searching for.
The additional CAN protocol allows the Haltech MXL Dash to interface with external expansion modules.
Haltech MXL PRO
If you’re looking for excellence, the most performing data acquisition system, the Haltech MXL PRO has everything you need to bring you on the top of the podium. Featuring 1 RPM input, 4 wheel speed inputs, 6 configurable alarm leds, 10 fully configurable shift lights, gear number display, internat lateral G sensor, 16 Megabytes of internal memory, 12 configurable channels, kit’s sensors and infrared transmitters and receivers, Haltech MXL PRO is your ultimate choice.
Use the Autosport connector and deploy a powerful array of sensors on your vehicle, including pressure, temperature, throttle, steering, suspension, wheel speed, Lambda sond, and more. The additional CAN protocol allows the Haltech MXL Dash to interface with external expansion modules.
The Haltech MXL Dash can be interfaced (via CAN or RS-232 serial) with a variety of Haltech ECU’s.
http://www.haltech.com/images/dash_tech.gif​
Connect the Haltech MXL Dash to your vehicle’s ECU and unleash the MXL’s true power: Logging and displaying dozens of channels straight from the vehicle’s nerve center, including specialised sensors built into the vehicle. This is often the quickest and easiest setup, needing only 1 cable connection to the ECU instead of multiple connections to analog sensors, yet it yields the most dramatic results.
Get the most from practice and training sessions by objectively comparing data from runs using different vehicle setups, drivers, and driving strategies to find the winning combinations. The Haltech MXL Dash uses state of the art algorithms to sample, calculate and display RPM, lap time, gear
position, wheel speed, temperatures and more.
Also with an optional GPS module you can create detailed 3D track maps.
http://www.haltech.com/images/haltech_mxl_dash.jpg
Haltech MXL Dash
http://www.haltech.com/images/dash_install.jpg
Haltech MXL Dash Installed
The Haltech MXL Dash is available in 3 versions:
STREET: Same as Track, no sampling capability.
TRACK:
1 wheel speed, 8 analog inputs, AMP connectors, 8Mb memory.
PRO: 4 wheel speeds, 12 analog inputs, Deutsch connectors, 16Mb memory.
Kasi mati sama dia...
[FONT=Arial, Helvetica, sans-serif][SIZE=+2]Trim Module[/SIZE][/FONT]
The Trim control gives the operator a remote access control for finely adjusting either turbo boost, fuel or ignition trim. Can be used with or without a PC connected to the ECU. Ideal for tuning whilst on the dynamometer. It is suitable for use with all current model ECU’s and supports:
+/- 12.5% fuel mixture
+/- 50% fuel mixture
+/- 10 degrees ignition timing
+/- 10 degrees trailing split (Rotary engines only)
0 – 100% turbo boost control
http://www.haltech.com/images/trim.jpg
RRP: $82.00 AUD
Best of all, whose car in ZTH feature in Haltech?
[FONT=Arial, Helvetica, sans-serif][SIZE=+2]Toyota Supra JZA80 1997[/SIZE][/FONT]
Engine modifications: HKS 272’ Racing Cam Shafts, HKS Cam Gear Pulley, JUN valve springs & retainers, Cometic Metal Head Gaskets, Clevite Race Bearings.
Cooling System: Fluidyne Radiator, TRD Thermostat, Samco Radiator Hoses.
Turbos: Holset HX50 Single Turbo Setup, Custom Twin Entry Turbo Extractor, Twin Tial 1 bar external WasteGates, Trust 3 core Intercooler, Samco Intercooler Hoses, HKS EVC4 Electronic Boost Controller, 4” Exhaust system.
Transmission: RPS Clutch System.
ECU: Powered by Haltech E11v2
Fuelling: Twin 255lph Internal Walbro Fuel Pumps, 6 x 1000cc Sard Top Feed Injectors, SARD Fuel Rail.
Power: 600bhp with 68kg of torque on pump gas
http://www.haltech.com/images/toyota_supra5.jpghttp://www.haltech.com/images/toyota_supra4.jpg http://www.haltech.com/images/toyota_supra7.jpghttp://www.haltech.com/images/toyota_supra2.jpghttp://www.haltech.com/images/toyota_supra3.jpgTuning/Wiring by: GT Auto Service Centre - Malaysia
Tell me which looks pro?
Microtech
Here comes Autronic....
Look at how precise are they.......
[FONT=Arial, Helvetica, sans-serif]SMC Model ECU.[/FONT]
http://www.autronic.com/image_files/smc-kit-1-thumbnail.jpg
Click Image For Larger View
Autronic SMC is sequential 3D ECU available in three case styles, standard, sealed and water proof.
This is the biggest selling model and is suitable for most applications.
The Autronic SMC includes harness, air and water temp sensor, internal map sensor, fuel pump relay, PC data cable, calibration and data logging software, 100 page manual.
The internal map sensor is available in 1bar absolute or 4.4 bar absolute (50 psi).
Available with high current (low impedance) or low current (high impedance) injector drivers.
Harness is a flying lead type and has a connector which plugs into the Ecu, and has a socket for fuel pump relay, and socket for data cable connection to a IBM compatible PC or Laptop serial port. The other end of the harness has to be connected as per the wiring diagram .
The software is compatible with USB ports, when used with USB to serial adapter.
Features:
  • Sequential operation for 2 to 8 cylinder engines.
  • Eight injector ouputs.
  • Four ignition outputs
  • 3D fuel and Ignition maps.
  • User defined up to 32 RPM and 16 Load sites = 512 sites.
  • Anti-Lag.
  • Flat Shift (ver 1.19).
  • Data Logging.
  • Software selectable trigger angle.
  • Support for multi-tooth or missing teeth triggers.
  • Auxiliary outputs other than fuel pump control
  • 8 cyl engine = 1 (1 PWM output).
  • 6 cyl engine = 3 (1 PWM + 2 On/Off)
  • 4 cyl engine = 5(1 PWM + 4 On/Off)
  • Auxiliary outputs can be defined for boost control, nitrous oxide, camshaft
  • timing, AC, fan control, idle valve etc...
  • Available with high current drivers if required.
  • AutoTune option available.
  • Optional Water Proof case for marine or harsh environments
Overview and Specifications
OverView.
The Autronic SMC Sequential Engine Management System is a compact engine management control for all engine performance upgrades.
A user friendly Windows software allows the user to select the degree of sophistication required for each application. This program, in combination with intelligence within the management system, allows the user to select the finest calibration detail required to match the application, in absolute minimum of time.
This program provides the means of interrogating the engine management system enabling speedy diagnosis and calibration.
Usage.
These systems can cater for the requirements of virtually any spark ignition engine, including the following.
i. High output supercharged or turbocharged engines, with either multi point and/or center point injection.
ii. Rotary (Wankel) and two stroke engines.
ii. Engines having uneven firing sequences such as 2 and 4 cylinder "V" configuration motor cycle engines and V6 motor vehicle engines.
IMPORTANT:- Please note that this product is intended for high performance motor sport applications and compliance with statutory regulations when used on public roads cannot be guaranteed.
Features.
1. a. Eight injector drivers for full sequential operation on engines up to eight cylinders. May be set for 'semi-sequential' operation on engines having more than 8 cylinders. e.g:- 12 cylinder engine using 6 groups of 2 two cylinders.
b. All injector types catered for (0.9 ohm to 16 ohm coil resistance). Specify unit fitted with optional high current injector drivers for 0.9 ohm or twin injector applications.
2. User choice of manifold absolute pressure or throttle position as engine load input. Internal absolute
pressure sensor for simplified installation 0 to 200 kpa (0 to 29.4 PSI) and 0 to 300 kpa (0 to 44.1 PSI) available from stock. 0 to 450 kpa (0 to 66.1 PSI) available on request.
3. Single coil distributor, twin coil distributor or muilticoil distributor-less ignition configurations are possible on most engines.
4. Fitted with environmentally sealed connector the standard unit is splash proof. Units are available with double environmental sealing for use in the most arduous of applications (e.g:- rally, off-road and marine).
5. Auxiliary output function that can be used for any of the following:
i. Closed loop (feedback), boost control for turbocharged engines with rpm and temperature dependent calibration characteristic.
ii. Closed loop (feedback) idle speed control.
iii. Control of engine cooling fan.
iv. Programmable on/off control for solenoid or relay driving that operates according to engine speed and load (eg:- can be used for gear shift control or light, over rev indicator, inlet camshaft timing selection or control of a supplementary electric fuel pump that augments mechanical fuel pump delivery at low engine rpm only).
v. Fuel used pulse output to electric or electro-mechanical counter with resolution of 0.1 liter (or use with trip computer).
vi. Or even more sophisticated control function such as servo control of auxiliary butterfly for turbocharged applications requiring precise throttle control and minimum turbo lag.
6. Exhaust oxygen sensor input for sensing air/fuel ratio. Connect either a Bosch narrow band O2 sensor or for more demanding applications a Bosch wide band O2 sensor and Autronic Analyzer. The low cost narrow band sensor requires no interface adapters or expensive air/fuel ratio meters, and offers moderate accuracy and tolerance to leaded fuels. This function can be used to monitor air/fuel ratio during engine tuning or can be used for feedback control of air/fuel ratio for applications requiring exhaust catalytic conversion (feature available on request).
7. Diagnostic/Error indicator of sensor or ECU fault conditions with memory for detection of intermittent fault conditions. An external light may also be connected for remote indication of abnormal operation.
8. Precise spark advance control strategy for both static and dynamic operating conditions.
9. Unique calibration strategy allows accurate control of fuel delivery under both acceleration and deceleration.
10. User selectable spark and fuel delivery strategy for abnormal engine operation conditions to minimize possibility of engine damage whilst still maintaining engine operation.. (eg:- over heated or over boosted).
11. Comprehensive limp-home functions with user selectable default settings that ensure engine operation can continue after sensor failure has occurred.
12. Full compensation of engine control parameters for engine operation at any altitude (fuel delivery, ignition timing and boost pressure).
13. Adaptive learning (with memory) to minimize the number of user setups required and to provide optimal control of air/fuel ratio, boost pressure and idle stability.
14. Rev limiter with soft characteristic that uses a combination of fuel delivery and spark control.
15. Fuel pump safety shutoff. Pump stops 3 to 4 seconds after the engine stops.
16. Unit is ultra light weight/compact yet has sufficient drive capacity for high power continuous duty applications. (one unit OK for all applications from motor cycle to large capacity twin turbo engines).
17. Optional interface unit to allow sequential operation without the need for separate crank/camshaft sensors or special multi-sensor distributor.
Interface Requirements.
INPUTS
Sensors:
1. Ignition input Hall effect, (Also available for direct connection to magnetic reluctor type pick-ups).
2. No. 1 cylinder reference. (Also available for direct connection to magnetic reluctor type pickups).
3. Barometric pressure. (Internal to ECU).
4. Manifold pressure. (Internal to ECU).
5. Throttle position.
6. Intake air temperature.
7. Engine coolant temperature.
8. Exhaust oxygen. (or optional Wide Range Air/Fuel Ratio Sensor).
9. Idle mixture trim. (Internal to ECU and screwdriver adjustable from outside).
OUTPUTS
Main:
8 x injector outputs. (Optional 2 injectors per driver).
Ignition output:
Open collector output to any of the following:
1. Single coil high energy ignitions: Bosch 7 pin, Mitsubishi 3 pin.
2. Autronic Capacitor Discharge Ignition.
3. MSD 6A etc..
(4 outputs are available allowing multi coil distrubtor-less ignition for applications on engines up to 8 cylinders).
Auxiliary:
1. Fuel pump/injector fuel shut off safety relay.
2. Multifunction on/off or pulse width modulation output for either:
i. Engine cooling fan relay.
ii. Idle speed actuator. (Variable duty cycle single pole type, eg:- Bosch).
iii. Turbocharger wastegate control valve. (SEM, most OEM types or Autronic low or high capacity).
iv. Turbocharger auxiliary butterfly control motor.
v. General purpose duty cycle output with user define characteristic.
vi Fuel used pulse output. (for trip computer function)
SERIAL I/O
1. Communications with "IBM" compatible computer for calibration, fault diagnosis.
Specifications.
Microcomputer
Intel 16 bit running @ 16MhzSupply Voltage
Normal operation
Safe limits
6.2V to 23V DC continuous
+/- 24V (5 min)
+/- 80V alternator load dump (0.5 sec).
+/- 1000V inductive spike (10 usec)Current Drain
@ Engine idle
@ Max Engine Load
< 1 Amp.
< 16 Amp (less depending on injector type and number.Operating Temperature Range
Min
Max
- 40 deg C.
+ 85 deg C.Engine Cylinder Number Settings
Number of cylinders
1, 2, 3, 4, 5, 6, 7, 8, 10, 12, 14 and 16Engine RPM Range
0 to 30,000 RPM
0 to 16,000 RPM
0 to 15,000 RPM
Engines up to 4 cylinders
Engines up to 5 to 8 cylinders.
Engines 10 to 16 cylinders.Injection Duration Timing
Min
Max
Accuracy
Setting resolution
0.7 msec.
30 msec.
+/- < (10 usec + 1%)
0.1% approx.Injection Timing
Range
Accuracy
Setting resolution
0 to 720 deg (crank angle).
+/- < (1.4 deg + 0.3 msec).
2.8 deg.Ignition Timing
Advance range
Accuracy
Setting resolution
0 to 45 deg (crank angle).
+/- 0.2 deg (crank angle).
0.5 deg (crank angle).Fuel Delivery and Ignition Mapping
No. Load sites
No. RPM sites
16 (max). Both Load and RPM sites
32 (max). are freely selectable. Size
L * W * H
157 * 122 * 35 mm
180 * 128 * 35 mm (overall, including mounts & connector)Weight . 0.5 kgConnectors
36 way 'AMP' water and dust proof socket
[FONT=Arial, Helvetica, sans-serif]SM2 Model ECU.[/FONT]
Autronic SM2 is sequential 3D ECU.
This model is aimed at the serious racer. With traction control, it is ideal for circuit racing. (MAMA MIA)
The Autronic SM2 includes harness, air and water temp sensor, internal map sensor, fuel pump relay, PC data cable, calibration and data logging software, 100 page manual.
Harness is flying lead type and has a connector which plugs into the Ecu, and socket for fuel pump relay.
The data cable to connects between PC or Laptop serial port and socket on the ECU case.
Software is compatible with USB ports, when used with USB to serial adapter.
Features:
  • Four ignition ouputs (ignition expander available for up to 8 outputs)
  • Eight auxiliary outputs other than fuel pump control.
  • Auxiliary outputs can be defined for boost control, nitrous oxide, staged
  • injectors, camshaft timing, AC, fan control, idle valve etc...
  • Traction Control.
  • Flat Shift. (ver 1.92 & 1.93)
  • Launch Control. (ver 1.93)
  • Anti-Lag.
  • Data Logging.
  • Compatible with Motec Dash.
Overview.
The Autronic SM2 Sequential Engine Management System are versatile engine management controls for all engine performance upgrades. Their sophisticated features allow these products to provide performance that rivals even the most expensive European systems costing 3 to 10 times more.
Included are features previously found in Formula 1 level applications, yet this system has the flexibility to be used by the every day engine tuner for almost any high performance upgrade.
A user friendly Windows software program allows the user to select the degree of sophistication required for each application. This program, in combination with intelligence within the management system, allows the user to select the finest calibration detail required to match the application, in absolute minimum of time.
Usage.
Features.
4. Closed loop (feedback) boost pressure control for turbocharged engines with multiple calibration curves selectable by switch input or road speed (eg:- lower boost curve for use in low gear).
5. Closed loop (feedback) idle speed control.
8. Measurement of end correction for exhaust back pressure (applicable to turbocharged engines).
9. Control of engine cooling fans and coordination with air conditioner operation.
10. Programmable on/off output for solenoid or relay driving that operates according to engine speed and load (eg:- can be used for gear shift control or light, over rev indicator, inlet camshaft timing selection or control of a supplementary electric fuel pump that augments mechanical fuel pump delivery at low engine rpm only).
11. Precise spark advance control strategy for both static and dynamic operating conditions.
12. Unique calibration strategy allows accurate control of fuel delivery under both acceleration and deceleration.
13. User selectable spark and fuel delivery strategy for abnormal engine operation conditions to minimize possibility of engine damage whilst still maintaining engine operation.. (eg:- over heated or over boosted).
14. Comprehensive limp-home functions with user selectable default settings that ensure engine operation can continue after sensor failure has occurred.
15. User defined proportional output function that can be used for additional functions as outlined in 10 above or for a more sophisticated control function such as servo control of auxiliary butterfly for turbocharged applications requiring precise throttle control and minimum turbo lag.
16. Full compensation of engine control parameters for engine operation at any altitude (fuel delivery, ignition timing and boost pressure).
17. Adaptive learning (with memory) to minimize the number of user setups required and to provide optimal control of air/fuel ratio, boost pressure and idle stability.
18. Rev limiter with soft characteristic that uses a combination of fuel delivery and spark control.
19. Fuel pump safety shutoff. Pump stops 3 to 4 seconds after the engine stops.
20. Bi-directional input/output line for simultaneous connection of remote adjusting unit.
21. Standard unit is ultra light weight/compact yet has sufficient drive capacity for high power continuous duty applications. (one unit OK for all applications from motor cycle to large capacity twin turbo engines).
22. User configurable data logging of up to 17 channels with the selected channels being sampled as fast as 50 times a second. With 32k bytes of non volatile memory.
23. Optional interface unit to allow sequential operation without the need for separate crank/camshaft sensors or special multi-sensor distributor.
24. Fuel used pulse output to electronic or electromechanical counter with resolution of 0.1 liter (or use with trip computer).
25. Remote monitoring of all functions using telemetry adapter, ECU can perform simultaneous logging and telemetry.
26. Water injection/intercooler cooling for intake charge temperature control in turbo/super charged applications.
IINPUTS
Sensors:
1. Ignition input Hall effect, (Also available for direct connection to magnetic reluctor type pickups).
3. Road speed input. Hall effect (Also available for direct connection to magnetic reluctor type pickups).
4. Turbo speed input. Magnetic Reluctor (must use optional interface adapter).
5. Barometric pressure. (Internal to ECU).
6. Manifold pressure. (Internal to ECU).
7. Throttle position.
8. Intake air temperature.
9. Engine coolant temperature.
10. Exhaust back pressure (optional).
11. Exhaust oxygen. (or optional Wide Range Air/Fuel Ratio Sensor).
Auxiliary:
1. Air conditioner request.
2. Boost curve select.
Adjustments Idle mixture trim. (Internal to ECU and screwdriver adjustable from outside).
OUTPUTS
Main
1. 8 off injector driver. (Optional 2 injectors per driver).
2. 4 Ignition output.
3. MSD 6A etc..
Auxiliary:
2. Air conditioner clutch relay.
3. Engine/Air conditioner cooling fan relay.
4. Engine cooling fan relay.
5. Idle speed actuator. (Variable duty cycle single pole type, eg:- Bosch).
6. Turbocharger wastegate control valve. (SEM, most OEM types or Autronic low or high capacity).
7. Turbocharger auxiliary butterfly control motor.
8. Spare duty cycle output with user define characteristic.
9. Fuel used pulse output. (for trip computer function).
SERIAL I/O
Specifications.
Microcomputer
Normal operation
Safe limits
+/- 24V (5 min)
@ Engine idle
@ Max Engine Load
< 1 Amp.
Min
Max
- 40 deg C.
Number of cylinders
0 to 30,000 RPM
0 to 16,000 RPM
0 to 15,000 RPM
Min
Max
Accuracy
Setting resolution
0.7 msec.
30 msec.
Range
Accuracy
Setting resolution
Advance range
Accuracy
Setting resolution
No. Load sites
No. RPM sites
L * W * H
190 * 190 * 38 mm
235 * 190 * 38 mm (overall, including mounts & connector)Weight . 1.35 kgConnectors52 way 'AMP' socket using 3 separate plugs 10 way high current plug.
18 way low current plug.
24 way low current plug.
Miniature mic plug (3.5 mm stereo)
3 way for communications with laptop computer.
[FONT=Arial, Helvetica, sans-serif]SM4 Model ECU.[/FONT]
The SM4 is our latest model ECU. This ECU has many features which allow it to be setup to suit various types of engine configurations. It has very flexible options over how the inputs and outputs are controlled, and allows the user to design their own functions to control all sorts of devices. Precise control of injectors and ignition angle are guaranteed at very low or high RPM or manifold pressures. A very high level of protection from interference and tolerance of trigger input errors has been built into this ECU, ensuring a smooth running engine even under the most demanding conditions.
Variable camshaft control for up to two camshaft. Control of camshaft position is very precise and time taken to advance from full retard to full advance is less the 1 second. Support for most VVT and VANOS systems.
Closed loop control of idle speed and boost pressure makes for a "factory" idle speed stability, and precise control of boost pressure. Boost control can be setup to provide a different boost in each gear.
The optional internal knock control module gives one of the most advanced aftermarket knock control available. Knock control is user definable to use either fuel enrichment or ignition retard or a combination of both the control only the cylinders that have knock. (GENIEUS)
HARDWARE:
Main Connector 42 way sealed with protective cover.
PC serial data link connector 3 way 3.5 dia.
Case, silver extruded aluminium, 130 x 124 x 48 MM (overall).
Processor speed 25% faster & overall performance > 2.OX previous generation.
OK to 13,000 rpm on 16 cylinder engine. 1 to 12 cylinders to > 16000rpm.
ECU to PC data link operates at up to 115k baud for fast cal down load & Log file upload (19sec typ for 112k bytes). 112k logging memory.
Internal Diagnostic light & optional remote light.
High efficiency power supply & output drivers for reduced power consumption and reduced self-heating.
Four ignition outputs. (With external multiplexer up to eight) Rating Push-Pull +/-1 amp max. Up to 3 useable for alternate functions.
Software selectable mappable dwell or O/P pulse duration modes possible.
Four coil dwell, software selectable. (With external multiplexer up to eight)
Eight injector outputs. Rating selectable software 4/1 amp 2/0.5 amp peak/hold type for high & low current injector types or parallel operation of injector pairs. Rating may be specified independently for 2 groups of 4 O/Ps. Sequential, single or double shot 1 or 2 group fire possible for up to 16 injectors. Up to 7 useable for alternate functions.
10 General purpose (GP) outputs
3 PWM (dedicated)
5 Pull-down @ 3.5 amp max
1 Pull-down @ 1 amp max
4 Push-Pull @ +/- 1 amp max (also suitable for stepper motor control).
15 PWM using GP outputs, spare Injector or Ignition O/Ps. All have 1 OHz min, 3 have upper limit of 50OHz, 2 have upper limit of 1.2KHz.
In-built dual reluctor interface / hall effect interface. Camshaft & crankshaft sensor inputs individually software configurable for hall effect & reluctor sensor types. Response speed is also software configurable for improved noise immunity.
Three general purpose digital Inputs with logic level sensitivity & pullup to +5volts. Useable for speed measurement. Switch I/Ps. Two are useable for Camshaft position measurement.
Knock control with individual cylinder retard (requires installation of additional internal module).
Variable Camshaft control for up to two camshafts. VANOS and other VVT and VVT-i supported.
Autronic or NTC air temp sensors, software selectable.
Internal or external map sensor, software selectable.
High and low injector driver software selectable.
Stepper motor idle control.
Support for most idle valve type including 2 wire, 3 wire & stepper possible. Stepper pins can be used for spare outputs if not used for idle control.
Support for air flow meters.
Internal Pressure sensor useable for MAP &/or barometric sensing.
Tacho & Diagnostic outputs.
3 x Spare Analog inputs (EGT, EBP, 02, etc...) Spare analog Inputs may be used as additional low speed digital inputs (eg:- switch inputs). Two have dual logic levels (two switch levels per input)
Analog inputs can be set for predefined calibrations or user defined calibrations.
SOFTWARE:
Autotune (self tuning software).
Launch Control (two step rev limiter based on vehicle speed).
Flatshift (change gears without clutch at WOT using standard gearbox).
Antilag (keep turbocharger on boost during gear changes) with turbo cooldown function.
Selectable ignition tables. Output tables can be based on any X and Y axis parmentier.
Fuel and ignition tables have 32 rpm and 16 load site axis.
Many correction tables for precision fuel & ignition adaption.
Table axis values totally user selectable.
Multi tooth, missing tooth, Subaru, Mitsubishi, Ford TFI and Gen3 triggers. Software selectable trigger angle.
Support for two and three rotor engines with ignition split.
Dedicated idle control with additional settings for better adaption to changing operating condition and a more stable idle.
Dedicated Closed loop boost control, and other settings for stable boost pressures. Dedicated A/C compressor control.
Dedicated twin cooling fan control.
Dedicated NOS injection control, coordinates fuel & ignition.
13 General purpose control modules for O/P control. (use for variable fuel pump, power steering, inlet manifold air valves, extra temperature control devices etc) 4 of these are capable of PID feedback control (typical application for PIDs are variable camshaft positioning or inlet manifold length).
Mapping via manifold pressure, throttle position, manifold and throttle or manifold, throttle and exhaust backpressure.
Case Dimensions:
L = 130mm (5-1/8")
W = 124mm (4-7/8")
H = 48mm (1-7/8")
Weight = 0.5kg (1.1 lbs)
For more information and wiring diagrams dlownload the SM4 software from this page. Press F1 in menus for help. Wiring diagrams are under the help menu.​
Specifications.
Microcomputer
Intel 16 bit running @ 20MhzSupply Voltage
Normal operation
Safe limits
+/- 24V (5 min)
@ Engine idle
@ Max Engine Load
< 1 Amp.
Min
Max
- 40 deg C.
Number of cylinders
0 to 30,000 RPM
0 to 16,000 RPM
0 to 15,000 RPM
Min
Max
Accuracy
Settingresolution
0.65 msec.
50 msec.
Range
Accuracy
Settingresolution
Advance range
Accuracy
Settingresolution
No. Load sites
No. RPM sites
32 (max). are freely selectable. Data Logging Memory
Size
112kSize
L * W * H
130 * 124 * 48mm Weight . 0.5 kgConnectors
42 way 'AMP' water and dust proof sockethttp://www.autronic.com/page_files/sm4_kit.htm#top
Kasi melt itu piston...
[FONT=Arial, Helvetica, sans-serif]Ignition Modules and Coils.[/FONT]
Note: Click on image for a larger view.
Bosch 008 Ignition Module and connector set.
This module provides dwell for ignition coils.
http://www.autronic.com/image_files/ignition_modules_and_coils/Boschmodule_thumbnail.jpg
Bosch Single Coil.
Small, compact and powerful, can be used as a single coil or for multi-coil setups.
Uses injector type connector. Can be used with Boosh 008 modules or R500 CDI.
http://www.autronic.com/image_files/ignition_modules_and_coils/Coilbosch_thumbnail.jpgDouble Ended Coil.
For use with wasted spark setups using Bosch modules or R500 CDI
http://www.autronic.com/image_files/ignition_modules_and_coils/DoubleCoil1_thumbnail.jpgDouble Ended Coil Pack.
http://www.autronic.com/image_files/ignition_modules_and_coils/DoubleCoilPack_thumbnail.gifGM LS1 Coil
This coil has an internal igniter and is ideal for use with the SM4 model ECU. Produces a spark powerful enough for turbocharged engines running up to 1.5 bar boost
http://www.autronic.com/image_files/ignition_modules_and_coils/LS1coil_thumbnail.jpgMultiplexer 5, 6 or 8 channels.
Used to get 5, 6 or 8 ignition outputs when using the SM4 model ECU. Typical applications are 5 cylinder engines and 3 rotor, rotary engines. Will work with stock ignition systems or CDI ignitions.
http://www.autronic.com/image_files/ignition_modules_and_coils/Multiplexer_thumnail.jpg
http://www.autronic.com/index.html#top
Cukup F1 tak?
[FONT=Arial, Helvetica, sans-serif]Telemetry Kit.[/FONT]
http://www.autronic.com/image_files/telemetry_kit/radiomodemkit_thumbnail.jpg
Tune, view and data log real time data with Autronic SMC, SM2 and Plug and Play boards at line of site distances of 3.5+ km.
The Autorinic calibration software can be used the same as if the normal PC Data Cable was connected between the ECU and PC.
With ECU's with chip versions 1.90 or higher the Virtual Dash software can be used.
The modems are spread spectrum and will frequency hop to maintain the connection. If the vehicle moves out of line of sight, the modems will wait until it reappears and continue transmitting the data.​
Up to five slaves modems can be used with one master. (Example:- monitor up to 5 race cars on a race track)
No license required in Australia, New Zealand, USA, Austria, Belgium, Denmark, France, Germany, Greece, Finland, Sweden, Ireland, Italy, Luxembourg, Spain, Netherlands and United Kingdom.
Kit includes:
  • 1 x Master Radio Modem
  • 1 x Slave Radio Modem
  • 1 x PC to Master Cable
  • 1 x ECU to Slave Cable
  • 1 x Master Base Antenna
  • 1 x Slave Antenna
  • 1 x Virtual Dash Software.
  • 1 x Manual (see Technical Data page )
Specifications
Power Supply.
The Autronic modems may be powered from either a 10 - 30 VDC or 10 - 24 VAC supply Normal current drain 70mA (@12VDC) or 50mA (@24VDC)
· Current when transmitting 350mA (@ 12V), 250mA (@ 24V).
· Low power mode, normal current drain is 20mA (@ 12VDC), 15mA (@24VDC)
General
· Environmental -30 to 60 degC (full performance), -40 to 70 degC (typical performance) 0 to 99 %RH
· EMC Compliant FCC Part 15 Class A
· Housing, extruded aluminium case 4.5" x 7.3" x 1.2" (114 x 185 x 30 mm), DIN rail mounting, removable terminal blocks for ease of module replacement, terminals suitable for 12 gauge (2.5sqmm) conductors.
· LED indication for unit OK, radio TX and RX, serial TX and RX, DCD (comms OK).
Serial Port
· Standard data rates 1200 to 115200 baud. · RS232 and RS485 standard interface connections provided, each connected to the same serial port. Serial interfaces are asynchronous non-return-zero (NRZ) format.
· The following characters are supported (selectable) - 7 data bits, even or odd parity,1 start bit,1 or 2 stop bits; 7 data bits, no parity,1 start bit, 2 stop bits; 8 data bits, even or odd or no parity, 1 start bit,1 stop bit
· RS232 connection provides full duplex operation as a DCE device with RTS/CTS hardware handshaking- standard D9 connector.
· RS485 connection provides half duplex operation for twisted-pair multidrop networks.
· Terminal connectors provided for RS485.
Radio Transceiver
· Frequency Hopping Spread Spectrum Transceiver
· Frequency USA/Canada 902 - 928 MHz, Australia 915 - 928 MHz, NZ 921 - 928MHz, EU Countries 869MHz - 870MHz.
· Hop Sequence Length - 50
· Available Sequences - 16
· Transmit Power 1W · RSSI -60 to -120 dBm
· Signal Strength Indication -120 dBm to -80 dBm
· Expected line-of-sight range, depending on local conditions
· USA/Canada 20+ miles, Australia/NZ 20+ km, EU Countries 5+ km.
· RF Data Transmission Rate - 19200 baud, 57600 baud, 115200 baud
· Range may be extended by:- - up to five intermediate repeaters for controlled mode - inlimited repeaters
for transparent mode
· Conforms to FCC Part 15 Class A and FCC Part 15.247
· Antenna connection is SMA coaxial
Cukup F1 tak?
Kit includes:
  • 1 x Slave Antenna
This is interesting!!
