HWL adjustable problem, need help
howiechoo said:
it;s just a discussion..
a discussion could also end up in flames... so better stop before too late...
Target Design said:
the seller said just over warranty...and he already bring to factory to services before warrant over...
so.,i think condition are still ok.
anyway thanks all the sifu here.....
thank you
you should still give the condition a check before you make the deal.. most important is if there are any dents on the damper case... any scratches on the rod... other than that it should be fine...
is it any cheaper than buying a new set??? cos sometimes a new set is only a bit more than buying an old set and revalving it...
Target Design said:
the seller sell me RM800....izzit worth or not with this price?
new one i think is RM1680
it is the best you check with them on the price of servicing a set of Waja adjustables...
then there are the workmanship price for installing the adjustables on your car... you add here and there... sometimes it is more worth buying a new set if it is only a bit extra... got warranty somemore...just my opinion
Write your reply...
