- Joined
- Dec 5, 2004
- Messages
- 93
- Points
- 3,006
guys, what wrong wt my engine if oil found on the floor? makan oil and oil leak are two different thing right?
comment pls???
comment pls???
If oil leak .. you need to find out where it leaks. It can be from your gasket site or oil seal site. Clean your engine and let it dry ... slowly notice it leak from where before you send to garage ...Originally posted by mirage2929@Jan 19 2005, 19:19
comment pls???
hi, ive disabled the PCV breather which normally runs from the top of the blockOriginally posted by Supachip@Jan 17 2005, 12:59
You suspected that the engine oil went into combustion chamber through PCV system (breather)?
I think that will only happen if the oil is overfilled gua.
4G15 (FI) engine, I think PCV is the rubber hose attached to the intake pipe. normallly there's a one way valve to prevent this.
If the breather is blocked, engine oil will seep out from crankcase coz too much pressure in within.
| hi i wanna sell my evo 9 manufacture year 2005 register year 2006 import baru ap baru stock standard accident free aluminum roof mivec turbo 6 speed regular service recaro leather seats cd... |
