Help on suspension
softmuffin
Hi there,
I hope someone can help me with me with my problem.
I just change my satria 1.6 suspension to Ori GTi suspension with spring.
The problem is my front is higher them my rear or somehow front and rear also same height.
It is 1.6 and 1.8 spring is the same? or the GTI front suspension only for SGTI?
If i change the shock but use back the GTI spring, will it help or i change the GTI spring but use back the GTI shock?
gti
GTI 4g93 engine is much heavier then 1.6 4g92, therefore
obviously the front will be much higher...
in tat case, will it help if i change the shock to 1.6 type but use back the SGTI spring
or change the spring to 1.6 but use back the ori SGTi shock?
you mean use back my 1.6 spring with the SGTI shock or new 1.6 shock with SGTI spring?
putra4767 said:
u have to use back ur spring, only then it will be lower....
