Help on Evo 7 Problem
pedanglaut
26
1,503
Hi all, anyone ever experience car running only 2 piston suddenly when cruising?when stopped the engine and start back, the engine went normal back. When this happened, i've check the fuel pressure on regulator is normal.
No presence of any check light though.
This problem became more frequent recently and i suspect the problem came from one of following parts:
1. Sparkplugs kong (1 year old)
2. Ignition coil
3. Injector
I hope someone ever experience this could give helpful input before i start to fix/replace those suspected part to avoid unnecessary spending.
Thanks in advance guys.:biggrin:
will3830
Jul 25, 2010
39
508
I have this issue before, for my case is one of the ignition coil pack rosak.
If not mistaken, Evo are 1 coil pack for 2 piston, so if coil pack rosak u will felt car running on 2 piston only.
Hope this help.
pedanglaut
26
1,503
normally its the spark plugs.
Hope this help.
Happens to me once..the ignition coil kaput..so,change both with halfcut one n now run perfectly..
Thanks guys.
I'll start with sparkplugs first and coil if still happen.:driver:
4gbanger
1,958
386
1,683
Johor/ShahAlam
makesure u have the right plug for evo.. last time some dumb mechanic use other car's plug n when i floor pedal, the plug seem week. the plug only last 3-4 month also.
madiewaters
463
18
plug also got different type for evo 7/8 is same but evo 9 is different lenght
EvolutionZ
5,000 RPM
5,025
1,448
Send to mech for a thorough check to prevent further damage... IMHO
pedanglaut
26
1,503
Hi guys,
Quick updates on my ride prob previously,
It seems only sparkplugs got problem to date, i've done 150 km (mix of cruising and full boost sessions) on new plugs and so far so good.
Thanks guys.
Anyone know how to diy 5 wire Daihatsu side mirror?
is it complicated? can teach me? already have wire for all side mirror?:adore::adore::confused:
