Help!!! hard to start
lek9925
my car is hard to start when engine is hot..... when cold start is normal but after drive u start again it won start just crank only...... any one can help?
Re: Help!!! hart to start
brother you try to pm kool or midship brother.cz it 1zz i better now but sw must ask this two person.....sorry !!!but i think your problem cooland sistem:driver:
Check batt voltage, plugs + cable, fuse and starter.
as mentioned, & while you are at it, get shop to see if alternator is charging.
now i trying starter ...... looking 4 part at sarawak....
---------- Post added at 11:05 PM ---------- Previous post was at 11:04 PM ----------
hope is the starter fails....
---------- Post added at 11:10 PM ---------- Previous post was at 11:05 PM ----------
Alternator is charging is the starter keep on cranking , i think is magnetic switch jam..
finally my car is alive!!! thanks 4 helps guy..... just the starter relay only.....hahahaha
If it is starter relay, it won't crank at all in the first place.
Relay OK --> can crank
Relay NG --> cannot crank at all
Your problem is quite similar to the symptom of a faulty ECU (early stage).
Perhaps you should check your ECU immediately.
Good luck!
the starter relay is a solid-state type in most modern cars these days and have a tendency of deteriorating after some number of years in use especially in a very frequent engine starting and cutting-off. As u hv mentioned tat it occurs only during hot engine start, it could possibly be the unit itself having loose contacts in it and this will leave you with a "tuck tuck" sound but without the ability to crank the engine at all. However, once the engine is much colder, it will be abled to close back the contact and allow u to have the engine to crank again. However, since u could crank the engine but could not get it to ignite, it could be the setting out ur fuel/air mixture being too lean. Perhaps, u could look into it as well.
i seldom to use my MR2 only got start for worm up sometime. so now got many problem have to fix. haizzzz....... if i want to change clutch disc need to put the engine down? and the timing belt also......? is it difficult?
bro can i have ur pic of ur car with mr2 engine?
bro any one know where can i find the cosco absober uper mount with pilla ball.... my one got noise le.........
