Help!!! hard to start
lek9925
37
my car is hard to start when engine is hot..... when cold start is normal but after drive u start again it won start just crank only...... any one can help?
lek9925
37
Re: Help!!! hart to start
sw20 engine is 3sgte.......
1198
111
johor bahru
brother you try to pm kool or midship brother.cz it 1zz i better now but sw must ask this two person.....sorry !!!but i think your problem cooland sistem:driver:
koolspyda
2,889
55
KayEl
koolspyda.blogspot.com
Check batt voltage, plugs + cable, fuse and starter.
as mentioned, & while you are at it, get shop to see if alternator is charging.
lek9925
37
now i trying starter ...... looking 4 part at sarawak....
---------- Post added at 11:05 PM ---------- Previous post was at 11:04 PM ----------
hope is the starter fails....
---------- Post added at 11:10 PM ---------- Previous post was at 11:05 PM ----------
Alternator is charging is the starter keep on cranking , i think is magnetic switch jam..
lek9925
37
finally my car is alive!!! thanks 4 helps guy..... just the starter relay only.....hahahaha
levin818
1,260
321
3,183
Shah Alam
If it is starter relay, it won't crank at all in the first place.
Relay OK --> can crank
Relay NG --> cannot crank at all
Your problem is quite similar to the symptom of a faulty ECU (early stage).
Perhaps you should check your ECU immediately.
Good luck!
alray
264
5,018
Selangor
the starter relay is a solid-state type in most modern cars these days and have a tendency of deteriorating after some number of years in use especially in a very frequent engine starting and cutting-off. As u hv mentioned tat it occurs only during hot engine start, it could possibly be the unit itself having loose contacts in it and this will leave you with a "tuck tuck" sound but without the ability to crank the engine at all. However, once the engine is much colder, it will be abled to close back the contact and allow u to have the engine to crank again. However, since u could crank the engine but could not get it to ignite, it could be the setting out ur fuel/air mixture being too lean. Perhaps, u could look into it as well.
lek9925
37
i seldom to use my MR2 only got start for worm up sometime. so now got many problem have to fix. haizzzz....... if i want to change clutch disc need to put the engine down? and the timing belt also......? is it difficult?
keisukosan
316
7
bro can i have ur pic of ur car with mr2 engine?
lek9925
37
bro any one know where can i find the cosco absober uper mount with pilla ball.... my one got noise le.........
hi bros and siss, i was about to change my spark plug from stock to iridium type, but i just wonder which one is better. denso has its reputation in its performance and durability, especially with its 0.4mm and it U-grooved. but wat i know about volker iridium performing good also. it has 0.5mm and can last up to 160,000km. budget wise, both is about the same. however, for Gen2, wat do u guys think? which one is better? o there is other recommendation? 1 more ques, about denso iridium POWER...
