To all sifus out there.....I need help urgently......Thanks in advance for all ur feedbacks....
Currently i'm driving a Wira with 4G61T manual transmission.....
The problem i'm facing is that.....My car's idling is smooth at times....idling around 1100 on idle with the a/c on....but after running the engine for awhile then as i am slowing down....the car's rpm would drop till about 300rpm n then will rise back again until 1500rpm then the engine would suddenly stall....this incident doesn't happen when the engine is cold or running on short distances.....and also not all the time when i'm trying to slow down....it syok syok happens....and when this happens, on the attempt of slowing down before the engine stalls, the rpm will be a bit sluggish.....
I've been trying to troubleshoot this problem for quite some time already but still couldn't manage to pin-point the fault.....I've cleaned the trottlebody, replace the engine temperature sensor, replace a brand new K&N air filter and also checking the fuel line....
I've got some parts that i've suspected for the fault, but not very sure whether those parts does control the idling part of the car....the parts are rpm sensor, oxygen(O2) sensor or the Idling Speed Controller(ISC).....
This problem occured the day after i've changed the timing belt and also a new radiator....
I hope all you sifus out there would offer me some expert advice on solving this problem....it's getting me frustrated already....Thanks again.....
